Valve Adjustment on a 350 After Rebuild
Just wondering this winter if there is anything I need to do on the valve train for adjustment. Approx. 2000 miles after the rebuild. Slight tick on cold start up. Goes quiet when it gets warmer. Flat tappet cam. New rockers OEM style. Not rollers. Everything was new, new cam, tappets, push rods, valves, rockers, springs. Its 1975 350 with #5 heads on it. Engine runs real well. No issues. Just want to be proactive.
Yes they checked it, I know they ordered new pushrods for the proper length. It only sounds like one cylinder. I don't what the preload was measured at?
What should it be and how do you measure it? Is there another way to test?
Update
I found a loose bolt on the one manifolds. Tightened it up. I think I will pull the valve covers anyways as one is leaking. I did some research on my bill from the rebuilder and had forgot they installed comp kit 1441 roller tip rockers and set of comp push rods 7948. Without running the engine I should be able to check the preload on each lifter with the valve seated. Keep track of the adjustment turn and rotate the push rod. They mention the pushrod starts to get tight and another half turn for proper adjustment. Some people say a full turn. It’s been 3000 miles since the rebuild and I haven’t checked them. Thoughts?
Thanks for the tips guys. I will check it out. I don't want to touch much or adjust as it is running great. Just a slight tick when cold on start up. Possible just one valve or like I said I found a manifold bolt loose as well. Doesn't hurt to check when I have I have time this winter.
The noise is most likely an exhaust leak. I like to use a length of rubber tube (say, 3' or so), sick one end in my ear and move the other end around to isolate the noise. I find that better than the mechanic stethoscope.
Adjusting valves is a fine time honored tradition. I'd say go for it as it's a good thing to learn and pretty simple. Just need to keep track of what you're doing. Slightly too tight can hang a valve open which will just make it run poorly. Slightly too loose will make it rattle. Go too far either way and parts can break. But here, "slightly" means 1/4 to 1/2 turn, which is pretty easy to control when doing this.
There's no need to do a maintenance adjustment on hydraulic lifters - only solid lifters need to be checked and adjusted.
The pinch nuts that come with that kit are terrible, but doesn't mean you have to replace them. If using the pinch nuts, then go 1/2-ish turn past where the rocker just becomes seated. I prefer to jiggle the pushrod up and down rather than twist, but it all works.
With polylocks, you loosen the center set screw, set the lash (generally 1/2 turn past seated), get the set screw somewhat tightened down, then tighten the nut with the socket to really lock it in place. Just tightening the set screw does not lock the nut.
It's also easier for the pinch nuts to clear under stock valve covers than polylocks.
I like this guys method. I have used it several times and they come out perfect each time. And you don’t have to do it with the engine running and making a mess.
https://youtu.be/5EGlb_VpTAw
Why not do it right the first time. Read this
How to Adjust Valve Lash Using the EOIC Method (hotrod.com)
I recon there has been a fair amount of deals when using the Comp roller-tip kit, where their pushrods self-destroys by mushing either end of ball.
Worth a check if your onto it.
EDIT: Looked up and your part-number turns to Hi-tech pushrod line of theirs; theyve been their lowly magnum pushrods which been destroyed.
What a waste of time.
You can do the valves in whatever order you want, just make sure the lifter is on the base circle. Some methods are faster than others, but can be harder to keep track of what's done and what's not.
