Vacuum line layout for '54 Olds
Old Aug 5, 2008 | 09:08 PM
54olds's Avatar
Nothing new beats an Olds
I have reason to believe the vacuum lines on my '54 are run incorrectly. I have a shop manual, but I can't find any diagram showing which lines go where.
Can anyone post a diagram or tell me where the lines go?
Old Aug 7, 2008 | 12:20 AM
88 coupe's Avatar
Junior Member
From another thread, dealing with the same problem.
Originally Posted by 88 coupe
Originally Posted by 54olds
........ I'm suspecting that the vacuum lines may not be hookoed up correctly.
Here is a pic I took of the vacuum lines on my car:
Line A = Sends manifold vacuum to the inlet of the vacuum pump. Should be another line, sending it to the wiper motor.
Line B = Manifold vacuum for the power brakes = As it should be.
Line C = Vacuum originating from the "ported" source, at the carb, for use with vacuum advance only. The other line should go from the wiper motor to that "other" port on the vacuum pump.
Norm
MLK-442
May 15, 2026 07:42 AM
Jimi2much
Jan 8, 2014 04:34 PM
jbevins
Oct 15, 2013 05:26 PM
68conv455
May 20, 2008 02:03 PM
benkerr
Dec 30, 2007 01:15 PM
