Total noobie wants more power,
Hi
I have just gotten a 1977 Cutlass with a stock 350. the car is in really good shape and i want to keep it looking stock.
The problem is it has very little power. As far as i can tell it is bone stock with 76,000 miles.
1. I purchased a dual exhaust system from Summit, but have not installed it.
Should i make it true duals or just Y it off the stock exhaust system where it dumps into the converter. I'm planning on removing the converter
2.I'm guessing the motor could use some more compression, what's the limit with the stock cam? Is there a better flowing head available for a reasonable price? I'm thinking of removing the heads and milling them for more compression and cleaning up the ports. How much can be taken off the heads?
I didn't want to get into the shortblock, or the cam unless big gains were to be had.
I'm not looking for a tire burner, just something that will keep up with traffic.
Thanks in advance.
Thanks in advance.
Do a tune up on it with fresh parts (plugs, wires cap etc.) and make sure that the q-jet is going to full throttle on the secondary side. Many I have seen will not. Maybe even a rebuild on the q-jet could be in order. Check timing for 36 degrees at 3000 rpm. Make sure vacuum advance is working from timed spark port.
THEN the dual exhaust, AND a set of 3.23, or 3.42 gears in back will make a world of difference. You can probably find the gears in the wrecking yard from a Chevy truck CHEAP.
Jim
Jim
True duals = Dual exhaust, as opposed to fake duals. The second exhaust usually adds a noticeable power gain.
Y pipe = Dual outlet exhaust (fake duals). For appearance only. Gain, if any, will not be enough to measure.
Norm
Norm
Thanks, I believe i can remove the cat without hassle from authorities, so it's no concern.
any information on these heads? Think I could up the CR to 8.5 or 9?
How would the steeper rear gears affect Gas mileage? i suspected the poor gearing is largly responsible for the poor acceleration.
Norm, think I should get a shaved cam? a friend of mine has one in 76 442 and it runs 8's. (wink)
Steeper gears will cause the engine to spin more for each mile driven. Gives more mechanical leverage to move car. More fuel is burned for given distance, giving more effort towards moving vehicle, and also burning more fuel. If you have a mid 2 series gear, a low 3.?, it will make a hell of a difference in accelleration. Cost will be more fuel spent. There is a happy medium somewhere in this for you.
Do the tune-up first.
JMO
Jim
JMO
Jim
Thanks, I've been reading the whole site and related links.
I think i'm going to try and find some better heads, true dual exhaust and see what happens.
i might move to a low 3.Xx gear.
I know from drag racing, gears make a huge difference, especially off the line.
That's a clean looking '77. You could raise your compression a bit by adding a set of Olds 350 #5 heads (64cc). Also, you could replace your TH350 transmission with a 4-speed OD transmission (700R4 or 2004R) and change gears to 3.73 or 3.42. If you go the head route, replace your timing chain and oil pump while your at it. A car that nice deserves a freshly rebuilt motor.
If you could "swing it", do a complete engine rebuild via a reputable shop. A quality Olds 350 rebuild might cost between $3,500.-$4,000. If you decide to go that route in the future, try to find an unrebuilt '69-'72 Olds 350 motor, or even an Olds 403. These offer good foundations for a strong runner, especially if the parts are matched properly. Realistically, you could have a mild small-block Olds under your hood that makes 350 horses / 370 FT LBS of torque.
PS - the 4-speed OD will do wonders for off-the-line acceleration & driveability for cruising; also, you could add a Holley Pro-Jection 4D set-up (throttle body fuel injection) for an AWESOME TIRE FRYING COMBO!
Take Care,
Rolo
Take Care,
Rolo
That is a pretty car. Too bad they are so small. After doing a tune up and rebuilding the carburetor I suggest headers and an aftermarket cam. Those would be the easiest ways to bump up your horse power without doing too much to the car.
Yea, the vw only weighs in at 1500 lbs, with 200 hp. No ac, no radio, rides like a buck board, and noisy as hell.
I think that's why i love the Oldsmobile, it's like, wow, i got a real car now.
I love them both, but they are totally different.
His 3A heads should be around 75cc's.
What year and model is a good donor for the #5 heads? Anything else to look out for? How hard is it to port and polish the #5 heads? How much can you shave the head while still making it drivable and what gains would result?
The #5s were used on every 350 Olds built in 1968-1969, including W-31s. They are no different to work on than any other Olds head. The amount you can cut is a function of how much CR you plan to run and what the rest of the engine looks like. For example, the current FelPro blue head gaskets have significantly greater compressed thickness than the OEM steel shim gaskets. This will drop compression. You need to get an accurate measurement of your deck height, piston dish volume, head gasket compressed height, and desired chamber volume to determine actual CR.
How did "tolerance stack" figure into the decision?
........ to allow for a head resurfacing in addition to production tolerances ........
........ You need to get an accurate measurement of your deck height, piston dish volume, head gasket compressed height, and desired chamber volume to determine actual CR.
Norm
These heads normally do not warp, and seldom need resurfacing.
Not to forget the bore, stroke, rod length, and pin (compression) height of the piston.
Norm
Norm
An example of stacked tolerances, as applied to this thread, would be:
........ and yes, I know what happens when one assumes ........
........ the larger-than-advertised chamber volumes seen on as-cast heads ........
........ was an allowance for variables like core shrinkage and shift such that the CR would never exceed the design point .........
........ thus detonation should not have been a problem when the car was tuned to factory specs ........
........ but that's why you blueprint motors, right? ........
........ Maybe so, but again, as an engineer, I would design for that option ........
You've told us what you would do, and I don't disagree with your thinking.
My question is: What was actually done?
........ I'll admit ........
........ I may not be 100% complete in my responses.
The “crime” is when omissions/errors of fact, are allowed to go uncorrected. 442.com/Oldsfaq is a good example of the consequences.
Norm
Norm only has a problem with the redundancy in the name. Dual outlet exhaust looked great on my Specials and Skylarks.
If, at a 30-40 miles per hour cruise, you feel/hear a slight surge/miss you can go a "taste" richer on the primaries. If not, relax and enjoy it.
A 2200 RPM, or so, stall converter will work well with that combination. Do the gears first.
Norm
........ more torque multiplication via 3.23 ........
Norm
Unfortunately, I am not aware of any published factory data that describes as-cast chamber volumes. The only published data is the minimum CC data that NHRA publishes, which presumably came from the factory originally, but obviously these are not as-cast. I will note that some of the chamber size data that's listed in the FAQ was based on measurements performed by Chris Witt. Note that most of these measurements were based on a single data point (ie, a single copy of each casting) and thus should not be taken as gospel but an indication only.
Blue Beast
March 21st, 2013 06:32 PM
