Timing cover Crank seal
This is likely no difficult task but work with me, I can't find a previous thread discussing this and this is my first car
So I bought a second 350 olds that I am going to paint and re gasket, I am going to put it in my car while I build my real engine, that way I can work out all of the kinks.
I am about to re gasket but I am having trouble with the timing cover crank seal, I have the dry rubber out but how do I get out the metal ring? Do I just beat on it? The more detail I can get the better (pictures?)
I would really appreciate any help.
The metal ring and rubber seal are one piece and normally come out together. The metal is a press fit into the front cover. You need to beat it out from the back or use a puller from the front. The new seal is tapped into the front cover with a driver or an appropriately-sized length of pipe. It's a good idea to get a repair sleeve for the balancer if there is any question at all about the quality of the sealing surface.
