Timing Chain
Old Sep 16, 2013 | 07:16 AM
Jedidiah's Avatar
Timing Chain
My timing chain has gone out and now my oil pan and pickup is full of plastic bits.
I bought a nice Cloyes set to replace it.
Should I just get a new pickup or should I go ahead and get a nice new pump?
I don't want some crappy Chinese repro part, and the Melling pumps seem like quality parts.
If I were to go ahead and purchase a Melling M22FHV pump to replace the stock pump, do you think my bottom end would starve on a stock '72 350?
Old Sep 16, 2013 | 07:22 AM
Jedidiah's Avatar
More information you may need to know.
The car has approximately 77k miles on it (maybe less, it had undersized tires on it for like 12 years)
It maintains 50 psi of oil pressure on the highway and about 20-25 at a redlight.
Old Sep 16, 2013 | 08:12 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You can reuse the oil pump, just clean out the pick up really well. A high volume pump won't starve your engine but isn't necessary.
Old Sep 16, 2013 | 08:14 AM
Jedidiah's Avatar
OK thanks. Should I go ahead and replace the oil pump driveshaft while I'm at it?
Old Sep 16, 2013 | 08:16 AM
I would never replace the oil pump driveshaft unless it was damaged. It is just a rod that goes from the bottom of the distributor to the oil pump.
Old Sep 16, 2013 | 08:17 AM
X2 on above and you can also reuse your oil pump drive.
Old Sep 16, 2013 | 08:23 AM
Jedidiah's Avatar
OK. I'll just clean out my current pickup. Thanks for the replies.
Old Sep 16, 2013 | 08:44 AM
Oh, not again...
The HV pump will NOT "suck the pan dry".
Old Sep 16, 2013 | 01:54 PM
Jedidiah's Avatar
Oh, not again...
I found a nice thread about the HV pump on here just before you posted. I should have mentioned that in my previous post. Thanks for the reply anyway.
http
Apr 26, 2013 09:58 AM
442scotty
May 13, 2009 05:42 PM
dccutlass
Sep 17, 2007 03:08 PM
Mr. King
Mar 25, 2007 12:33 PM
olds87
May 24, 2006 08:30 PM
