throttle linkage
Old May 31, 2023 | 03:34 AM
GKranig1's Avatar
throttle linkage
The automatic throttle linkage on my 66 cutlass is real close to the wires for the HEI distributor,is there aftermarket linkage available or does somebody have a standard shift linkage for sale that would give more room. Thank you. Note: It is not the original transmission. Now it's a TH 350 and the motor is now a 350 cu in motor.
Old May 31, 2023 | 04:25 AM
If you are still running the stock transmission, you may want to rethink this. Is your distributor clocked correctly?
Old May 31, 2023 | 06:53 AM
OK, but so what? Is there a problem? If you're worried about wear on the wires, use a wire loom to hold them up.
Old May 31, 2023 | 12:20 PM
BillK's Avatar
A picture would help in trying to come up with a solution.
67abody
Oct 18, 2015 06:19 AM
lemoldsnut
Sep 24, 2014 03:30 AM
4424me
May 13, 2012 06:02 PM
66ninetyeightls
May 18, 2010 02:59 PM
gearheads78
Aug 6, 2008 07:44 PM
