Thorton manifolds on a 68 350"
Old October 22nd, 2016 | 06:21 PM
starfire65's Avatar
If you have a 68 cutlass and plan on using Thorton exhaust manifolds with the factory hot air shield on the passenger side be prepared for a lot of work. Spent about 2 1/2 to 3 hours making them work. Wanted to keep the factory look as much as possible. The good thing is no cutting on the heat shield just some creative bending and a little hammer work. The manifold lots of work! You will have to grind or mill the ribs cast into the new design. I used my milling machine and a ball nose end mill but a hand grinder will work. Enclosed are some pics. Good luck!!
Old October 22nd, 2016 | 08:24 PM
RetroRanger's Avatar
72 Olds CS
Good pics I wonder if the later year heat shield will fit w less work?
JpMotorsports
December 11th, 2014 06:30 AM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
1969w3155
December 21st, 2010 09:44 PM
sx455raidercelticfan
December 21st, 2010 05:19 PM
Quick Reply: Thorton manifolds on a 68 350"
