Things to Consider, 350 Build
Old Oct 18, 2010 | 12:39 PM
SPEEDROCKET's Avatar
Ok, I'm starting at step 1 here, about a year ago I had my 73 cutlass stolen and the only thing I had left was this 350 block and heads. So, I figured since I'm starting from the ground up, it would be a good time to ask the questions and get going in the right direction. I'm listing quite a bit here but am by no means sold on any of the ideas yet, that's why I'm asking you guys first. Here's what I have to work with:
350 block (all info points to the 68-72 year, but the far left serial number starts with a 33M) It's bored .30 over right now
7a heads, looks to be stock for the most part, maybe at best mild port matching
stock cast crank
seems to be stock connecting rods
speed pro flat top pistons
and a decently nice harmonic balancer
I'm not starting with much I know, but want to get off on the right foot. I have a good(condition wise) cam but have no idea what the specs are on it, no idea how to find out. This engine was rebuilt when I got it and to me seemed to be a mismatch because it just felt flat when it comes to the seat of the pants feeling. I'm trying to find out before I put this thing back together, how strong the stock connecting rods are, what will they tolerate in terms of RPM's and TQ/HP?
When it comes to puting the rest on the engine together I was trying to figure out what a good match would be for carb/ intake/ cam would be. Kind of leaning toward Edelbrock performer RPM stuff, but haven't heard all that great of stuff about the cam side of the house. My first choice would be to run a Q-jet but since I don't have one it makes it kind of difficult to do that, so would a 600-700cfm carb do the trick to match the #7111 intake?
I have no valvetrain either, so was wondering what anybody thought of the COMP 1441-kit offered at summitracing, if it would work or not, have heard from time to time that certain valvetrains don't do well in the Olds motors. For reliability I was considering a main gridle from DMR, and also adding the lifter bore and cam bearing restrictors to the engine since it's still disassembled, was also thinking oil pan baffle also.
In the future I plan to find a g body cutlass shell and so far want to lean toward a built 200r4 for the tranny if this is any help with other information. I have also considered getting the crank drilled now to accept a TKO-500 in the far future, not to sure about that yet though.
This is just a few thoughts I have right now, of course, we all know there are many more steps after all this is done. I thank anybody for taking the time to reply with advice in advance.
Old Oct 18, 2010 | 12:43 PM
Is this post working?
Old Oct 18, 2010 | 01:37 PM
6inarow's Avatar
Yes your post showed up. Someone that knows about building Olds 350s will come along and help you out. Sounds like a cool project.
Old Oct 18, 2010 | 03:18 PM
Sorry for double post, didn't realize I did that.
Old Oct 18, 2010 | 06:55 PM
cutlassefi's Avatar
Desired hp? Budget?
A Performer RPM and Qjet is fine. A cam in the 220 @ .050 range will give you good power and retain driveability. Try to go with 1.7 rockers, more lift more hp. Roller Cam? I can grind you whatever you want.
Shoot for 9.5:1 or better. 2.00 intakes and head work (filled crossovers etc.) would be well suited as well.
That should get you started.
IMO don't need a main girdle or restrictors. Stock rods and crank are fine as well if you stay below 500hp.
Mark
Old Oct 18, 2010 | 07:13 PM
Desired hp? Budget?
>well budget is up in the air, since I'm not in a major hurry, I just want to make sure I do it right, I haven't really desired HP as much as TQ, but would love to have gobs of TQ!
>Was looking into cams, I'm not real sure what brand to go with, as far as roller... vs. hydraulic flat am I really going to get $600+ performance difference out of the roller? Just something I have no idea on and is why I'm asking. If I go with 1.7 rockers, what size would that make my pushrods(or is this for a machinist to solve)? As far as carbs go, what would be a good alternative if I can't find a Q-jet that works for this application?
>I defiantly like the sounds of the 2.00 intakes(heard that could be worth 10 to 20hp by itself).. should I make the exhaust valve bigger just because it's in and getting done. With these 7a heads being 64cc's, will the flat top pistons I already have matched with the heads hit about 9.5:1? Or will more be required? Although I've seen people talking about filling the crossovers, what does that do for the engine?
>Thanks for the reply.
Mark
Old Oct 18, 2010 | 07:18 PM
don71's Avatar
same but different
Sorry about your 73. You can probably get this project going. Would you call this a street car or a race car?
I 'm not any good at suggesting cams or carbs but if you're on the cheap, then use what you got. Either one will work. About that cam, there should be some numbers stamped on the end. Post those numbers, somebody will probably recognize them. We can go from there.
I'm using a Torker intake. Thats what I got.
I would skip the comp1441 rockers. There just roller tipped, and not a full on roller rocker. Look into Harland Sharp rockers.
I would skip the girdle too. Spend that money on balancing the assembly along with the other machine work. Like a good valve job. Get to know a machinist if you don't all ready.
I would probably skip the restricters too, I don't think they are needed.
I like the idea of drilling the crank for a manual trans. Do it now and not later.
Old Oct 19, 2010 | 04:52 AM
cutlassefi's Avatar
Filling the crossovers and welding the port divider will enhance scavenging. In stock form your 7a heads are closer to 68cc. Keep the same exhaust valve. I'd shoot for 9.5:1. That allows you some good cam choices and not too demanding on fuel.
Old Oct 19, 2010 | 07:58 AM
>a streetable car that I might play with at the track?
>does Harland sharp offer a full kit? That's what I'm gunning for, since I have no valve train at all, the heads are fully assembled, the guy I got them off of said they had a 3 angle valve job done on them before I got it from him, the engine was together but there wasn't even oil in the engine yet when I got it.
>Balancing in my book is not an option, it's a must. But was just kicking around ideas to strengthen up that bottom end a little with the girdle.
>I've seen this used on a lot of topics on olds builds, I can't say I know exactly what they do or how they affect the engine in the end.
>Exactly what I was thinking, because if I ever do go the manual route, I'll be glad I did.
Old Oct 19, 2010 | 09:16 AM
Jon69's Avatar
On the topic of Cams.
Changing to a roller cam is something that I have planned for my 69. Not for performance but peace of mind. Modern motor oils do not protect a flat tappet cam, and you need to take some care in picking the right oil or oil+additive if you love the engine.
Convert it to a roller and you can run pretty much any motor oil.
Goggle "ZDDP" and you will find more info and opinions than you can shake a stick at.
Just something you might factor into your decision.
Old Oct 19, 2010 | 09:27 AM
Thanks for the input will defianetly check it out.
Old Oct 19, 2010 | 10:58 AM
>the number stamped on the cam is: CS176R, is there a way to determine lift and duration and kind of cam from this number?
>Also wanted to ask if you have a small block and you have a Torker on a small block and if so where I could find it at?
Old Oct 19, 2010 | 11:33 AM
From a site that usually isn't reliable I found that the CS176R cam is a sealed power cam and was an OEM replacement for the W-31 350 option, but does these numbers seem right?
Overlap Duration -Lift
82 -------308/308 .474/.474
If I decide to use this cam what would be a good Carb/Intake match for it? What kind of stall would I need for the torque converter? And where would that push to rear gear too if I planned to use the 200r4?
Old Oct 19, 2010 | 03:45 PM
cutlassefi's Avatar
A 1000 cfm carb and a 4000 rpm stall!
Just kidding but that's the W30/31 cam, not right for your combo.
I'd use a 1.7 rocker, and again a cam with intake duration in the 220 to maybe 230 range. Look for lifts in the .550 range with the 1.7 rockers. more lift is normally more hp everywhere in the powerband with no little or no downside if you have the springs for it.
Old Oct 19, 2010 | 04:24 PM
>LOL, that's funny I don't care who you are... thats funny right there!
>Ok, thanks for the reply, tossing the cam!
Old Oct 19, 2010 | 04:30 PM
Chesrown 67 OAI's Avatar
It is in DOVER, OH LOL
Who is it?
Old Oct 19, 2010 | 04:36 PM
call me sometime. I can give you line on lots of stuff for your 350 - even a complete motor if you wish -- right in your backyard!!
sending PM
Old Oct 21, 2010 | 05:36 PM
Jharken's Avatar
I would try to figure what kind of a performance goal you are looking to get.
Street/strip? street car, or race?
Pump gas or mix?
This will steer us in the right direction.
Old Oct 21, 2010 | 06:47 PM
Pump gas or mix?
Hmmm.... lets just say efficent, and smooth running, if there's a stupid honda(chevy or dodge) at a light acting a fool, I want to hand their A** to them, lol. So i guess the goal would be a strip car that I can drive to the track if I feel froggy.
pacekar
Jan 28, 2015 11:19 AM
ybicutty
Feb 11, 2013 10:52 PM
SPEEDROCKET
Oct 21, 2010 06:05 AM
Kidcutty
Apr 11, 2010 01:35 PM
Olds64
Aug 28, 2007 05:25 PM
