are there aluminum heads for an olds 350
Old May 19, 2010 | 12:46 AM
import extermination's Avatar
are there aftermarket heads make for the 350.
Old May 19, 2010 | 12:57 AM
cutlassefi's Avatar
Edelbrock.
Old May 19, 2010 | 09:04 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Can't run a mechanical fuel pump with e-brokes though, unless you make it happen.
As a bolt on, ABC-123.... I'd say no.
Old May 19, 2010 | 09:11 AM
80_cutlass's Avatar
What is the interference?
sb
Old May 19, 2010 | 09:58 AM
The head of the pump hits the side of the head.
Old May 19, 2010 | 10:15 AM
OLD SKL 69's Avatar
GM Enthusiast
Wow, you would have thought they could have fixed that. I guess you cannot grind away some of that aluminum to clear the pump?
Old May 19, 2010 | 10:17 AM
citcapp's Avatar
Because of the lower deck height of the 350. Several people run these with a electric fuel pump. Not sure if its worth it for the gain.
Old May 19, 2010 | 06:04 PM
svnt442's Avatar
One of the guys on another board has a mechanical pump on his 350 with Edelbrock heads, but he did some MAJOR surgery to the head to make it work. He didn't know about the issue and just started grinding on the head and hit the water jacket.
The heads were designed for use on the 400/425/455 and with those it's not an issue, but they will bolt on and work on a 330, 350, 403. It's just the fuel pump becomes an issue and depending on the year of the block so do the head bolt holes.
Old May 19, 2010 | 09:32 PM
Jim on here ended up welding and reshaping the entire water jacket.
There was another guy on R.O.P. that machined a spacer, and lengthened the fuel pump arm by cutting and welding it.
Old May 20, 2010 | 07:06 AM
507OLDS's Avatar
I think the Rocket Racing heads have a better clearance in that area,but I prefer the Edelbrocks.You have to use the Rocket Racing intake with their heads,so you only have one intake choice.All of the aftermarket heads will have the larger chambers for a 455,so you would need to mill them down to maintain the same compression.If you are starting from scratch,just put a flat-top piston in it,& less cutting,if any,on the head,depending on what compression you want to achieve.
Old May 20, 2010 | 04:01 PM
380 Racer's Avatar
Everybody complains about the Rocket Racing intake but it seems to work well on my combo. Just use the dyno to figure out spacers.
Old May 20, 2010 | 04:33 PM
z11375ss's Avatar
Senior Moment Member
Yeah, I put them on my small block. Big pain in the ***. 347hp, 388 torque@5100 rpm. You decide. If i had to do it again I would put a 455 in it.
Old May 21, 2010 | 05:11 AM
507OLDS's Avatar
Not saying it's a bad intake.It's just the limitation of choice.
Old May 21, 2010 | 07:17 PM
380 Racer's Avatar
May I ask what problems you had?
Old May 22, 2010 | 08:29 AM
captjim's Avatar
Nick, I think he is referring to e-brocks, IIRC.
Old May 22, 2010 | 05:58 PM
380 Racer's Avatar
OK thanks Jim.
Old May 24, 2010 | 02:47 AM
Aceshigh's Avatar
Definitely NOT worth the money. I looked into them for the sake of keeping my car all Olds.
Tell me this isn't sexy..... 400hp, 16mpg city / close to 28mpg hwy.
Old May 24, 2010 | 08:37 AM
Warhead's Avatar
FWIW, your avatar looks like mine trying to start with half of the plugs wires pulled.
Beautiful car, not sexy to me though.
Jim
Old May 24, 2010 | 09:01 AM
well i already have the ls1 motor in my trans am ( my daily driver), but to me a olds should stay an olds.
for me its more like, should i continue to build my 350, or should i do like everyone else and build a 455. haha
Old May 24, 2010 | 09:14 PM
Aceshigh's Avatar
Cool , cool.
I just wish there was a MUCH bigger aftermarket for Olds.
But there isn't......and modern technology blows it away for a fraction of
the $$$ some of these guys are charging. The Muscle Car era has been reborn.
I'm taking advantage of the technology in my classics.
But I will ALLLLLWAYS appreciate the big block power legend
Old May 25, 2010 | 04:02 AM
380 Racer's Avatar
If you are going to brag about your ls1, do it somewhere other than an Olds site. I hate to see a perfectly good Olds bastardized with a Chevy engine. Find a friggin Chevelle to put it in!!
Old May 25, 2010 | 11:57 AM
507OLDS's Avatar
If you are still running a SBO,look at a future build with a DX block.Yes,you can go to a 455,but you can build a DX & get sick with it.
Old May 25, 2010 | 06:05 PM
yeah im kinda on the fence. do i play with my small block or should i make the jump into a big block
right now i have a stock 1977 350 motor with 3A heads and a performer. getting married so im not into spending a ton of money, is it more expensive to stick with the small block and gradually build it?
Old May 29, 2010 | 10:17 AM
88 coupe's Avatar
Junior Member
Originally Posted by 507OLDS
........but you can build a DX & get sick with it.
Unless one has a compelling reason to use .921" lifters, a D block would be a better choice.
Norm
Old May 29, 2010 | 11:15 AM
z11375ss's Avatar
Put a big block in it. I have a small fortune in my small block. It runs great but in retrospect I wish I would have built a 455 instead. In fact I may anyway. I came that close to buying a short block over the winter. I already have all the new parts I need except for the intake.
Old May 29, 2010 | 05:34 PM
thanks z11375ss ill deffenetly keep that in mind when i start my engine build. i already have a nice 455 core, and i have the 77 350 rocket in my car.
Old Jun 2, 2010 | 09:26 AM
507OLDS's Avatar
I don't run the .921 lifters.Just have the lifter bores bushed.
Old Jul 12, 2015 | 08:30 PM
pablocutlass's Avatar
how mach mill the edelbrock head?
But how much is what must be lowered in the cylinder head edelbrock for a compression ratio of 10: 1 with a flat piston and a cylinder head gasket 4.125 x 0.027 for engine olds 355 or 350 + 030?
tocicar8825
Sep 21, 2021 07:10 AM
dave1978
Jan 9, 2021 07:13 AM
Zrzoun
Aug 16, 2015 08:45 AM
auto_editor
Sep 14, 2014 05:32 PM
stlregal
Dec 29, 2011 03:55 PM
