terrible exaust sound
Old Sep 14, 2013 | 01:13 PM
rmoths's Avatar
I always had a strange poping sound under hard acceleration.
Well I just put on new mufflers, Pypes Street Pro. They are very loud.
When I accelerate it has a very loud poping sound on one side from the exhaust, It sounds terrible. I'm wondering if I may have a bad valve or something. Just wondering if that's the way it sounds or if someone may have had the same problem. Barb.
Old Sep 14, 2013 | 02:17 PM
Any chance you're running lean?
Old Sep 14, 2013 | 04:15 PM
rmoths's Avatar
If so is that just a carb adjustment, Turn out the screw in front of the Carb.
Barb.
Old Sep 14, 2013 | 04:19 PM
jaunty75's Avatar
You're dragging the Bishop of Rome around under there! Stop it before you hurt him!
Old Sep 14, 2013 | 04:45 PM
Well, when you get his vestments disentangled from the driveshaft, he can go back home and drive his new Renault 4...
Old Sep 14, 2013 | 05:15 PM
tru-blue 442's Avatar
Old School Olds
Sounds like a sticking valve.
Possibly a valve with a weak spring.
Have you pulled the cover off the one
side making all the noise and taken a look?
I would also check for any bent pushrods.
Old Sep 14, 2013 | 05:21 PM
Beob's Avatar
A good place to start would be pull out the four plugs on the side that's popping and see what thier condition is. They should be tan in middle electrode and dry black on outer ring.
Old Sep 15, 2013 | 07:33 AM
rmoths's Avatar
Thanks for the replies. I looked at the plugs and they all look the same, Clean and dry. I think the valve spring or pushhrod could be the problem.
I know I have been running it to long this way and I'm afraid I may have a damaged valve now. I will have it checked out this week at my local shop. I know now I should have done this sooner. Thanks Barb.
Old Sep 15, 2013 | 01:51 PM
jfb's Avatar
jfb
hey buddie I had this once and due this before you go to a shop. I put my car on firm stands and put it in gear with another person putting it in gear and I had a exhaust leak. I am not guaranteeing it but maybe it is. just listen carefully for it.
gearheads78
Mar 3, 2015 02:12 PM
RickH
May 3, 2014 01:28 PM
1971 Supreme
Sep 21, 2012 08:47 PM
mutt
Jun 11, 2009 02:47 PM
63 F85 Cutlass
Dec 28, 2008 07:18 PM
