Temp sensor?????
Be sure to clean the threads and use Teflon pipe sealer to seal the threads. Be sure to tighten them adequately. Install the reducer first (adequately tightened), then the brass adapter. Good luck.
I agree there should be only one bushing for that sender, but maybe the installer used what he could easily find to adapt the sender to the port in the manifold.
And that brings up this observation - I see an EGR valve in the picture, so that intake manifold (and maybe the entire engine?) is a 1973-later vintage. Dunno if that would have any impact on the sender to intake size compatibility.
unfknthnkble
October 3rd, 2021 09:14 PM
