TCS solenoid
Old Nov 15, 2008 | 12:09 PM
woodie582's Avatar
TCS solenoid
I have a 71 350 with Performer RPM. I returned my original Q jet on the motor and have vacuam direct from carb to dist advance. Am I causeing problems by not haveing the TCS solenoid in place. Thanks
Old Nov 15, 2008 | 01:18 PM
Danny Wiseley's Avatar
The TCS switch was a smog-control device which kept vacuum away from the distributor unless the transmission was in high gear (or coincidentally, reverse gear.) You really don't need that.
DW
Old Nov 15, 2008 | 02:46 PM
DW
That's correct. This was an early attempt to control NOX emissions by limiting the vac advance. The TCS system also included a thermo valve to provide full vacuum to the distributor if the engine started to overheat. Again, you can bypass all of this if you don't care about originality.
Old Nov 15, 2008 | 03:57 PM
woodie582's Avatar
Thanks, for now its off.
stevengerard
Mar 10, 2021 07:29 AM
randomarrival
May 25, 2013 12:46 PM
72xw30
Nov 20, 2012 03:22 PM
StickW31
Sep 13, 2012 07:12 AM
Del70
Jul 11, 2011 09:10 PM
