switching intakes
Old Mar 27, 2011 | 06:14 PM
71Cutlass "S"'s Avatar
switching intakes
I just found out the 4bbl intake I purchased for my 71 350 rocket came off a 1966 330 will this intake work or do i need to get another one?
Old Mar 27, 2011 | 06:15 PM
intakes
Edit: Merged identical threads
Last edited by joe_padavano; Mar 27, 2011 at 07:09 PM. Reason: Merge identical threads
Old Mar 27, 2011 | 06:16 PM
jensenracing77's Avatar
it should work but will have the divorced choke.
Old Mar 27, 2011 | 06:35 PM
Still learning all the ins and outs and not sure what a divorced choke is but I am putting a Edelbrock 600 CFM carb on there
Old Mar 27, 2011 | 06:38 PM
I was going for the stock look but I might just go with a aluminum intake and paint it the original Olds gold
Old Mar 27, 2011 | 06:50 PM
The intake will bolt to a 350. The only problem is that the 66 intake is set up for a divorced choke - the choke coil sits in a pocket in the manifold. You can use a conventional hot air choke by using an aftermarket choke stove like this:
http://www.amazon.com/Mr-Gasket-3665.../dp/B000CMF0OC
Alternately, you can also convert the hot air choke to an electric choke by swapping the choke coil.
Old Mar 28, 2011 | 03:49 AM
Thanks for the help, it sounds like the Edelbrock with the electric choke will work just fine. All that is left is getting the block from the machine shop so I can put here back together and enjoy the ride.
John
shopaholic07
Aug 4, 2009 08:19 AM
cutty
Dec 16, 2008 03:46 PM
442scotty
Sep 16, 2008 04:54 PM
geckonz08
Aug 7, 2008 07:33 PM
nice72
Apr 7, 2008 06:26 AM
