swapping motors
Old March 5th, 2008, 10:31 PM
oldstay's Avatar
swapping motors
will a 1964 190 hp 330 fit in my 1963 f-85 instead of my 215?
oldstay is offline
Old March 6th, 2008, 06:16 AM
Depends. How are you with welding and fabricating?
The 61-63 cars are completely different from the 64-72 cars. For one thing, they're unibody as opposed to body-on-frame. The 215 uses a unique motor mounting and bellhousing design.
It's certainly POSSIBLE to fit a 330 (or any SBO - or BBO for that matter). Pontiac offered the 326 in the 1963 Tempest, so the SBO will likely fit. It will NOT be a bolt-in, however. You'll need to fabricate pretty much everything.
joe_padavano is online now
Old March 6th, 2008, 02:48 PM
Junior Member
88 coupe's Avatar
........ Pontiac offered the 326 in the 1963 Tempest ........
Standard was the "half 389" inline 4, which shared mounts with the optional 326. Made the 389/421 a bolt in, so the GTO could have easily happened a year earlier.
F-85/Cutlass/Jetfire and Special/Skylark front clips can be easily unbolted, and interchanged. If they are the same as Tempest/Lemans, it would make the conversion easier. Increased torque of the 330 might call for a sturdier drivetrain. Wimpy brakes would also need to be addressed.
Norm
88 coupe is offline
RichardWilliams
April 7th, 2009 08:18 AM
cts-v
January 10th, 2009 04:55 PM
jmac69cutty's
October 31st, 2008 12:28 PM
59-59-59
April 16th, 2008 09:13 PM
dhoopty
Drivetrain/Differentials
April 16th, 2008 09:45 AM
Quick Reply: swapping motors
