swap v6 to small block 77 Omega
hi, i have a 1977 Omega f85 with the standard buick v6 engine. Im swapping a 350 chevy small block and was wondering since the v8 was optional at the, will a small block fit right in or will i need to get new motor mounts? any advice is greatly appreciated
That would be incorrect. The Olds V8 is not a direct swap by any means. The trans bolts up, but that's about it. I know this is an Oldsmobile forum, but the Buick 350 IS an easy swap, IMHO.
So other than new frame mounts, new accessory brackets, new starter, new wiring harness, perhaps new condensor and radiator, new exhaust pipe, it is a direct swap? Posts like yours are what cause problems here, you need to be complete and not toss up some hasty, poorly written post which may lead to a guy getting frustrated when it really isn't that easy. Easier than a SBC? Maybe, but not by much.
I'll just shut up then....plus I never said tailpipe nor radiatior etc I'm not gonna start a fight but I ain't gonna sit back and take nothing from no one. My post may be 'hastly' written but I'm a lot busier than most 16 year olds and I'm still learning I'm doing the same swap as him and I was relaying what I have been told and to me what I was told
Last edited by billmerbach; April 15th, 2014 at 04:23 PM. Reason: speaking my mind
This is one of the big problems with our hobby, guys perpetuating bad info, just repeating things they have heard versus actually experiencing it. The Olds FAQ was a perfect example. I'm not telling you to shut up. But, if you make a post that is incorrect, someone will step in and say so. If I say something wrong, I expect someone to correct me. You gotta remember, when you make a post giving advice, some people may take that advice, whatever the subject. So, if you aren't sure, or have just heard, say it. Whenever I post something like that, I always qualify it by saying so.
