streetable cam???
Old Sep 14, 2008 | 08:55 PM
1971olds350's Avatar
streetable cam???
Mondello 22-25-10 is it streetable??? (a/c power brakes etc.). what comp ratio and stall is needed to run this setup? thanks...
Old Sep 14, 2008 | 09:16 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
JM-22-
25-10 0.512 0.523 274°/280° 230° 236° 110° 1400-6000
$149.00
Street with
Power Brakes
/Jet Boat
Old Sep 14, 2008 | 09:23 PM
I guess that's a yes
I'm not a torque converter expert at all, but I'd guess you would want your stall around 2500. That's one of those things I play around with for test and tunes.
OR..
you could call Coan or another like company, tell them your full setup, what it's for, and have them tell you.
Old Sep 15, 2008 | 09:48 AM
thank you
Old Sep 28, 2008 | 04:27 PM
djb56's Avatar
cam
I put a JM 20-22 IN MY 73-350. 496 lift, 226at@50. In order to keep it running when I dropped it in gear it had to idle at 1150rpm. What a thump. I put in a B&M 2500 stall and I was able to turn down the idle to 850 in park.
With a 230@50 on your cam you might have problems with power brakes at an idle. tHEY MIGHT FEEL LIKE YOUR PUSHING ON A BRICK TO GET THE CAR STOPPED. You might need a vacuum canister for your brakes.
Old Sep 28, 2008 | 07:10 PM
captjim's Avatar
I would think that in a 355, you will need 10.5-10.8 to 1 to make it idle decently and have enough vacuum for the brakes. You probably won't be running pump gas.
Old Sep 29, 2008 | 08:17 AM
88 coupe's Avatar
Junior Member
Originally Posted by 1971olds350
........ is it streetable? ........
Taking into consideration, that "Streetable" is a highly subjective term, as it has been applied to everything from a "stocker" (with a K&N, MSD, and a pair of Flowmasters) to a full on "racecar" (with mufflers, current registration, and insurance).
That cam (with a matching advance curve) can be a good choice for street use.
........ a/c power brakes ........
AC is not a factor. Whether PB are, depends on how the engine is tuned and the conditions when they are used. See "streetable" above.
There are reserve systems (PDF download) for use in "marginal" applications.
........ what comp ratio ........
Not subjective: Compression ratio depends on what fuel is to be used. 9.0:1 is usually suggested, as a starting point, for use with pump gas.
........ and stall ........
Converter stall speed is subjective: Depending on your intended use, your tires/suspension, and the rest of your powertrain, It might be anywhere between 2200 and 3500 RPM.
Originally Posted by captjim
........ you will need 10.5-10.8 to 1 to make it idle decently ........
Compression ratio has no effect on the idle
........ and have enough vacuum for the brakes ........
and little, if any, effect on the function of power brakes.
Norm
Old Nov 6, 2008 | 05:36 AM
cutlassefi's Avatar
Streetable Cam
Remember you can always advance or retard it to help give you what you want.
If you advance it 4-6 deg and it helps noticeably then you probably have the wrong cam for your application and wants, (too big).
If you retard it and it has the same effect then you could've probably gone a bit bigger.
Old Nov 6, 2008 | 11:31 AM
Redog's Avatar
Vacuum is very important in a street car.
The JM 22-25-10 is Streetable, the 20-22 is a good one too
Old Nov 6, 2008 | 01:29 PM
85olds442's Avatar
I have 2 Olds 350's a 77 with 7a heads and performer intake manifold. It makes around 270hp. Cam is .480 int / .496 exh 220 @.50 230. It ran High 13's at 5000ft elevation. The other 350 is a 68 with #6 heads Ported with a Isky Cam 538 lift 244 @.50 installed at 104. This has 11/1 comp with rpm with divider cut out. Ran a best of 12:53 @ 106 at 5000ft elevation in Pueblo Colorado. watch the video on youtube.com Mine's a 85 olds 442 grey in color. type in pueblo motorsports park oct 26-08 and the video is 9:08 long
Old Nov 7, 2008 | 03:43 AM
65cutty's Avatar
71olds350, you'll like the 22-25-10 its a good low end builder and yes you'll need a 2500 stall, mine will have the mondello roller tip rockers, guide's and push rods w/ studs, this winter, my comp is 9.3
Old Nov 18, 2008 | 10:49 AM
im also building a 2004r overdrive tranny so can i get a 3000 stall with lockup? or to much slip on part throttle. im also wondering how much horsepower is my motor going to make with 7 heads reworked bigger valves, 10.3 comp, 22-25-10 cam, edelbrock rpm intake, 750 edelbrock carb, headers, x pipe and flowmaster 40s. just curious
Old Nov 20, 2008 | 07:58 PM
does any1 know how much horsepower and torque 22-25-10 makes
Old Nov 21, 2008 | 04:29 AM
65cutty's Avatar
call jr or lynn at mondello at 805 237 8808 calif time zone they will tell you that info, best plan on valve springs? am building 75 350 block pistons and rods with 65 330 heads#2 and the 65 330 crank, hope this info helps you out, gives me 9.3 cp and using 22-25-10 cam and yes its good with power brakes
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
coldfire
Jul 25, 2013 05:26 PM
Rocket Richard
Feb 15, 2011 07:40 AM
