Squeeling 307
Old Mar 10, 2007 | 04:21 PM
falconsfan's Avatar
Squeeling 307
I have relaced the belts, have tightened to less than 1/2", have replaced the altenator, now heading toward replacing the fan clutch. The AIR pump and A/C compressor have been removed.
Only two belts remain, the altenator and the pwr steering belts.
It squeels (loudly) for the first 30 seconds or so at start-up.
Is it the fan clutch?
Is it the water pump?
is it bad pulleys?
Old Mar 10, 2007 | 04:35 PM
Oldsmaniac's Avatar
Most likely the pulleys are glazed and mirror smooth shiny....scuff em with some coarse emory cloth then tighten belts and all should be well....if belts are glazed try roughing them up too or replace.
Old Mar 10, 2007 | 07:19 PM
DonFrost's Avatar
I would check the tension of the belt. I have solved my problem by leaving the air pump and the ac unit and belt intact but removed all related gear for each (air tubes and associated vac lines, the a/c lines, condenser, drier and such) this equalizes the tension and will stop your squeeling and save your water pump (stress on the bearing) In the other thread they talk about moving the Alt to the passenger side to eliminate problems.
Old Mar 11, 2007 | 07:43 AM
falconsfan's Avatar
After reading both threads, Ive decided to put the AIR pump back on as well as the A/C belt.
The previous owner of the car had removed the AIR pump, can someone tell me if there was a specific bracket for this, or did it mount to the A/C bracket??
Old Mar 12, 2007 | 07:37 PM
soocutlass's Avatar
To remedy a squeally belt try running a bar of soap along the belt while it is running
Old Mar 13, 2007 | 03:44 PM
falconsfan's Avatar
Wet or dry?
Old Mar 13, 2007 | 06:43 PM
soocutlass's Avatar
Use a dry bar of soap
carbonf00tprint
Nov 4, 2012 07:53 AM
<bigdisel42>
Apr 23, 2005 09:44 PM
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
leo lymen
Dec 13, 2002 06:48 PM
