Spark Plugs and Valve Cover Gaskets
Old Oct 13, 2010 | 10:53 AM
Jannebill's Avatar
Hi,
I will be changing my sparkplus on my 72 Cutlass. It has a 350 Rocket, can you recommend the best brand to get on a budget. Do you think I would need to change my plug wires? I have seen that is the engine is stock you gap at .035 or .040. Is this correct? The engine is stock.
Also, I will be changing my valve cover gaskets, I assume I will need to put some gasket seal on these.. My assumption would be to make sure the areas are clean on the block and cover, add seal to gasket and slap it on the cover. Do i need the gasket seal on both side??
Thanks for your help, I am so excited!!!
Old Oct 13, 2010 | 10:58 AM
Oldsguy's Avatar
Past Administrator
AC plugs have worked for me. Use a cork valve cover gasket and apply some gasket cement or sealant on the valve cover side only. Make sure the surfaces are absolutely clean and the gasket mating surfaces on the valve covers are flat. Over-tightening over the years can dimple them and make sealing less effective
Old Oct 13, 2010 | 11:01 AM
Oldsguy's Avatar
Past Administrator
If you feel up to it you can get the generic cut-to-fit plug wire set, it will save you money but you must be very careful when crimping on the connectors.
Old Oct 13, 2010 | 11:55 AM
stlbluesbrother's Avatar
Just today I bought a PermaDryPlus (VS13403T) valve cover gasket from RockAuto based on information from this link: https://classicoldsmobile.com/forums...r-gaskets.html
If interested there is only 1 left at RockAuto and it's around $40 shipped
For more information on this topic scroll to the bottom of this page and check out the 'Similar Threads' section.
Ddbord
Apr 12, 2012 06:50 PM
Aceshigh
Mar 27, 2010 08:36 AM
miho35o
May 24, 2009 04:32 AM
miho35o
Mar 28, 2009 09:41 PM
dallas6778
Nov 20, 2007 10:04 AM
