Source for EGR block off plate?
Old Feb 3, 2017 | 09:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I am running two EGR manifolds with the valve deleted. I quite often cut the head off the EGR valves and fill but a plate looks better and have misplaced my spare valve. Edelbrock doesn't sell it seperate. Route 66 sells a custom one that looks right, they may not ship to Canada. Thanks.
Old Feb 3, 2017 | 10:38 AM
Once again, Google is your friend.
http://www.djsgmc.com/NewParts/EGRBlockOff.html
$10 with gasket. This is from the GMC motorhome crowd. Guess what engine they use.
By the way, this same vendor sells the choke stove blockoff and the mechanical fuel pump blockoff.
http://www.djsgmc.com/NewParts/default.html
Old Feb 3, 2017 | 12:58 PM
I did Joe, didn't see it thanks.
Old Feb 4, 2017 | 09:35 AM
I emailed both the sellers, hopefully they will respond or it will be plan B.
Old Feb 4, 2017 | 10:20 AM
Or you can do what we did before you could buy block of plates, make your own out of flat stock.
Old Feb 4, 2017 | 11:32 AM
That is plan B, cut a piece of flat sheet metal and spend a bunch of time to fit it nice or cut the head off the EGR valve, seal and we are good to go.
Old Feb 6, 2017 | 07:47 PM
cjsdad's Avatar
I think it took me all of 30 minutes to carve this out of a piece of scrap aluminum with a hacksaw and a drill. I used the gasket as a pattern. It isn't pretty but c'mon, it's an EGR block-off plate. It isn't sexy to begin with. It doesn't look so bad once the air cleaner is on.
Old Feb 6, 2017 | 08:36 PM
Looks good. The guy from Joe's link contacted me. It has to be extra heavy duty for the mighty 260.
Old Feb 6, 2017 | 08:51 PM
cjsdad's Avatar
Mine is 3/16 inch thick. Should be robust enough for the massive mouse motor.
gmarquez
Oct 7, 2015 04:49 PM
terrapin
Dec 13, 2014 02:54 PM
69ishHoliday
Jul 16, 2013 04:37 PM
mmcilroy
Aug 26, 2010 08:42 AM
Chumley
Jun 24, 2009 08:40 PM
