Small Block Trouble!
Old March 22nd, 2014, 02:42 PM
81cutlassSBC's Avatar
I hope I dont get too much crap for havin a chevy motor in my oldsmobile but I'm having a bit of trouble with mine and looking for someone who might have some insight into my situation cuz im at wits end... its an 86 SBC engine 355, turbo 350 trans and a stock ten bolt. Motor has a thumpr series cam in it with world sportsman class 2 heads on it and has been decked with 12-1 compression. Has an edelbrock performer intake and a quick fuel 750 carb on it. Has a turbo 350 with reverse manual valve body 3500 stall shift kit etc.
Now as for my fueling situation I bought the car with this engine in it and at the time it had a 950 holley with no choke on it which I felt was a bit much so I swapped it out for a 750 quick fuel carb with electric choke. I've been tinkering with the car a bit to get it ready for spring and on the first halfway decent day we had I took the car for a spin only to find the car spitting and sputtering pretty bad and when I shut the engine off it turned itself backwards so I assumed the timing needed to be redone. I pulled the distributor out AS WELL AS the spark plugs and went to turn the engine over with a ratchet and socket on the crank bolt only to find that the engine wont turn over... At first people were freaking me out saying the motor was junk because someone didnt put main caps correctly on or pistons in backwards etc. But Ive talked to a few other people who say if that were the case the engine wouldnt of ran fine before... I bought the car in a storage warehouse drove it outside and around the block a few times and it was fine. Then trailered it home where Ive been messing with it since and this was the first time I drove it since buying it and since changing the carb but it ran n drove fine originally with the 950 on when i bought it. It made no bad noises from the engine or anything and was running about a half hour before I pulled the dizzy and plugs out of it so Im at a loss with how I can turn the engine over to reset my timing at TDC. The crank bolt just keeps getting tighter and tighter... HELP PLEASE!!!!!!!!!!!
81cutlassSBC is offline
Old March 22nd, 2014, 02:43 PM
also just a side not if I bump the key the engine rolls over competely fine with the starter just not by hand at ALL not a single MM!
bocoogto
August 26th, 2023 06:09 PM
antweave
April 22nd, 2011 11:32 PM
olds4life
February 9th, 2010 08:48 AM
davepnola
December 18th, 2009 05:50 AM
citcapp
January 31st, 2009 04:01 PM
Quick Reply: Small Block Trouble!
