Silly mechanical fuel pump question
![Red face](https://classicoldsmobile.com/forums/images/icons/icon11.gif)
I think I know the answer to this but have to ask anyway -
If you put your finger over the suction inlet and crank the engine, you should feel a suction, right?
I feel nothing and no fuel comes out. Gas tank is full, car has been sitting for 6 months, and it ran perfectly when last parked. I am guessing the diaphragm dried out and cracked, thanks to the crappy ethenol.
Just need some confirmations before changing it.
Thanks!
Edit -old one was an airtex, installed 10 years ago.
Is Carter or spectra any better than airtex? Airtex was the cheapest...
Thanks!
Well I pulled the pump off this evening. took all of 10 minutes, included gathering the tools.
The lever moves up and down but the pump plunger does not. Looks like a keeper came off or something. Glad it happened while sitting in the driveway and not on the road!
It was a Carter, bought in 2000. I have the receipt and will claim the lifetime warranty on it tomorrow. Parts store ordered one and should be there now.
Cheap and easy - I love old cars!!
EDIT - it was not the keeper - i was not pulling the lever hard enough. The diaphragm had ruptured.
It always makes you stop and think when it happens in the driveway. I know you have traveled a lot in your car. Might think about a spare and the tools to change it.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Hmmm, maybe we should tow a car just like the one we are driving and then .... Oh, what am I thinking.
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
Well, i got the pump replaced for free at Oreillys - love that lifetime warranty!
Easy as can be, too, even for a 13 year old part.
Very friendly folds at the store i went to.
Lifetime warranty is gone now and everything is just a year. I suspect modern part quality might be to blame. Only time will tell though.
The old one had a ruptured diaphragm, and as a result no suction. Earlier I was not pulling the lever hard enough to pull the plunger. I suspect our crappy fuel did this. As the car sat, fuel leaked back into the tank and the diaphragm dried out too many times.
I found that while covering the inlet on the new pump, I could not even pull the lever all the way down. It sucked hard!
In thinking about that, i do not recommend trying to check for suction at the pump with your fingers!
Pump was installed in half an hour and car runs great now. I love how old cars are so easy to work on for the most part.![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
I have the premier level of AAA, so if anything happens to any of my cars, I will just have it towed back to the house. So far I never had to use it, but it is good piece of mind. Breakdowns only happen at the most inconvenient times i have found....
