Should i manually prime lifters?
Old Apr 18, 2020 | 11:16 AM
smokinjos's Avatar
Hi guys! My question is should i pull my lifters and manually prime? Last time car actually ran (20 years ago) i could"nt tell if it was exhaust manifold leak or lifter knock. 350 rocket rebuilt 25 years ago. about 1500 miles on engine
Old Apr 18, 2020 | 11:35 AM
v8al's Avatar
Registered Olds Owner
Manually prime by pulling the distributor and using a cordless drill and a 5/16 socket. Be sure not to drop anything down the distributor hole! With valve cover removed prime pump until oil comes out all push rods.
Old Apr 18, 2020 | 11:37 AM
jensenracing77's Avatar
I just pull the distributor and turn the oil pump with a drill. After about 2 or 3 minutes of that I will turn the engine 1/4 turn and do it again. I do that about 7 or 8 times and call it good. In extreme cases I will pull the valve covers and loosen up the rockers and check to see if any of the valves are stuck and see the oil coming out each rocker as I prime. If it was stored well and dry, Many people just crank it and start it up as it sits. I don't like doing it that way on a good engine but I have done it before.
Old Apr 18, 2020 | 11:40 AM
smokinjos's Avatar
Thnx V8al!! I've actually already done that. Didn't know if that was sufficient
Old Apr 18, 2020 | 11:41 AM
smokinjos's Avatar
Nice!! Thank you!!
Old Apr 18, 2020 | 03:28 PM
I manually prime brand new lifters by putting each one in a coffee can full of oil and using a drill press to push on the lifter with an old pushrod. If the lifters have already been run, there's no reason to manually prime them. Just pull the distributor and prime the motor, as noted above.
shockrebuild
Aug 17, 2019 02:53 PM
84oldshurst
Mar 25, 2019 03:55 PM
AtomicT
Jun 12, 2017 08:37 PM
Mrwee
Jun 27, 2016 07:05 AM
rtpassini
Dec 24, 2009 07:51 AM
