Serpinetine systems
Old December 27th, 2013, 01:57 AM
Oldskool84's Avatar
Serpinetine systems
What are the pros and cons of serpinetine systems?
Oldskool84 is offline
Old December 27th, 2013, 03:00 AM
Pros: Everyone will be impressed that you spent so much money on something that provides absolutely no improvement in function.
Cons: You'll spend a lot of money on something that provides absolutely no improvement in function.
MDchanic is offline
Old December 27th, 2013, 07:28 AM
Factory serpentine systems with a real reverse rotation water pump are designed to save cost and weight. Aftermarket psuedo-serpentine systems that use a conventional water pump and a boatload of idler pulleys to get sufficient belt contact force do a great job of separating the buyer from a couple thousand dollars. The extra idler pulleys also impart higher side force on the water pump bearings, shortening pump life and increasing lost horsepower.
These systems are bling for posers.
joe_padavano is offline
Old December 27th, 2013, 07:29 AM
455man's Avatar
^ That was pretty much my conclusion after researching it also. I think I heard some people say they liked having one belt instead of 3.
455man is offline
Old December 27th, 2013, 07:59 AM
Ask those people how much they like having only one belt after they toss the belt on the road. With multiple belts, break one and at least the water pump keeps turning, so you can drive to a place where you can get a new belt. Throw the single serpentine and you're dead in the water.
Old December 27th, 2013, 08:09 AM
Exactly.
MDchanic is offline
Old December 27th, 2013, 08:44 AM
455man's Avatar
Yeah I didnt understand the reasoning either.
455man is offline
Old December 27th, 2013, 10:36 AM
Oldskool84's Avatar
Ok.... I thought i was alone in thinking these were pointless. At the same time , I've seen so many ads for them that I started to think " maybe they know something that i dont?"
Old December 27th, 2013, 10:55 AM
They have something I don't, money to spend on useless things.
oldcutlass is online now
Old December 27th, 2013, 01:04 PM
Hookers under Hood
76olds's Avatar
I have to say I looked at them I personally think they look great under the hood, But way too expensive, Also march pulleys say its an edelbrock water pump for the olds, but I can find one.
76olds is offline
citcapp
February 14th, 2011 01:59 PM
Del70
October 22nd, 2010 06:22 PM
Eddie Hansen
Paint
21
February 12th, 2009 08:58 AM
tarheeldoc
August 27th, 2008 11:51 AM
kvenza
January 6th, 2008 05:49 AM
Quick Reply: Serpinetine systems
