In search of a 5.6" water pump pulley
Not sure if this one exists but I think the pulley I need is a 5.6" double groove 2.25" deep. The application is a 70 350 which was removed from an A/C car. The water pump is a short snout not original.
If such a pulley exists could someone please provide a part number and/or
application.
application.
Ok, so what is the engine going in? Get the correct pulley and water pump configuration and that way you don't have to worry about doing a mix and match hoping to make it work.
It will also make it easier down the road if you ever need to replace the water pump.
application.
application.
Found what I need. Thanks all.
81 regency
April 21st, 2011 06:18 PM
