roller rockarms ticking
Hope you used a zinc additive, and didn't wipe the cam!
With roller rockers, I believe you're supposed to also use oil restricted pushrods and guideplates!?!?!
Re-adjust - if it happens again, cut open your oil filter and look for metal.
If it's there, you get to start over!
x2 with cutlassjoe mine tick slightly nothing major just compnents moving doing their job. id be alarmed if it got worse check your oil and if nothing changes noise wise you are fine. Mine have sounded the same since the first start up
gibbo69olds
October 3rd, 2007 06:39 AM
