rocker setup smallblock/bigblock
Old April 11th, 2015 | 02:17 PM
Marx3's Avatar
Hi, I notice a difference in the design of the rockers and brackets between older heads and "newer" 4A heads.
Is it possible to take the whole rocker setup from an 4A head and bolt it on a #7 head or a B head?
Old April 11th, 2015 | 02:50 PM
Octania's Avatar
#7 yes
A and #2 heads are 1965 issue, and they use a single year only different rocker setup with studs that have I believe 3/8" thread into the heads. All other heads 1966+ [B-Ka and #3-on] should be able to use the same rockers.
Old April 11th, 2015 | 02:56 PM
Marx3's Avatar
so even though the setup looks different between #7 and 4A, they should interchange?
I am not sure what they are called, girdles maybe? the bracket-thing that holds both rockers down with two bolts are different on the 4A head than on the #7 head.
Old April 11th, 2015 | 04:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Keep in mind if you mill the heads a lot, your lifter preload will be too tight with factory length pushrods. Just mentioning it, goes with your other thread.
Old April 11th, 2015 | 04:38 PM
It's called a bridge and there are two designs, the three-piece design (two die cast trunnions with a stamped sheet metal bridge) and the one-piece design (trunnions and bridge in one die-cast piece). As Chris noted, other than the 1965-unique parts that fit the 3/8" studs, all are interchangeable.
Old April 11th, 2015 | 04:42 PM
Marx3's Avatar
ahh a bridge, thanks :-)
Okay, which is the 4A design then?
Old April 11th, 2015 | 04:45 PM
Should be the one-piece die cast design.
Old April 12th, 2015 | 06:02 AM
Marx3's Avatar
ok. Thanks!
February 3rd, 2013 06:39 AM
June 27th, 2012 06:59 AM
cory455olds
Suspension & Handling
May 18th, 2012 10:32 PM
mutzi
November 28th, 2008 05:58 PM
mutzi
November 26th, 2008 08:20 AM
