rocker setup smallblock/bigblock
Old Apr 11, 2015 | 01:17 PM
Marx3's Avatar
Hi, I notice a difference in the design of the rockers and brackets between older heads and "newer" 4A heads.
Is it possible to take the whole rocker setup from an 4A head and bolt it on a #7 head or a B head?
Old Apr 11, 2015 | 01:50 PM
Octania's Avatar
#7 yes
A and #2 heads are 1965 issue, and they use a single year only different rocker setup with studs that have I believe 3/8" thread into the heads. All other heads 1966+ [B-Ka and #3-on] should be able to use the same rockers.
Old Apr 11, 2015 | 01:56 PM
Marx3's Avatar
so even though the setup looks different between #7 and 4A, they should interchange?
I am not sure what they are called, girdles maybe? the bracket-thing that holds both rockers down with two bolts are different on the 4A head than on the #7 head.
Old Apr 11, 2015 | 03:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Keep in mind if you mill the heads a lot, your lifter preload will be too tight with factory length pushrods. Just mentioning it, goes with your other thread.
Old Apr 11, 2015 | 03:38 PM
It's called a bridge and there are two designs, the three-piece design (two die cast trunnions with a stamped sheet metal bridge) and the one-piece design (trunnions and bridge in one die-cast piece). As Chris noted, other than the 1965-unique parts that fit the 3/8" studs, all are interchangeable.
Old Apr 11, 2015 | 03:42 PM
Marx3's Avatar
ahh a bridge, thanks :-)
Okay, which is the 4A design then?
Old Apr 11, 2015 | 03:45 PM
Should be the one-piece die cast design.
Old Apr 12, 2015 | 05:02 AM
Marx3's Avatar
ok. Thanks!
Feb 3, 2013 05:39 AM
Jun 27, 2012 05:59 AM
cory455olds
Suspension & Handling
May 18, 2012 09:32 PM
mutzi
Nov 28, 2008 04:58 PM
mutzi
Nov 26, 2008 07:20 AM
