Rocker Binding on stud base
Old Jan 31, 2012 | 09:51 AM
ggriffin1960's Avatar
Question Rocker Binding on stud base
I am rebuilding a 1972 350 Olds engine and ran into an issue. I was checking for proper push rod length and notice the pattern on the valve tip was low (toward exhaust side). I tried to shorten the adjustable checker and the rocker itself bottomed out on the stud prior to acheiving the proper position on the valve stem. I am using Comp Cam roller tip rockers and hydraulic lifters, but the guide plates and studs are ones I purchased years ago for my 425 from Mondello. Any thoughts?
Old Jan 31, 2012 | 05:48 PM
Rickman48's Avatar
Try switching the rocker - gotta start somewhere!
Old Jan 31, 2012 | 06:27 PM
TripDeuces's Avatar
You need a longer slot in the rocker. What's the lift on the cam?
Old Jan 31, 2012 | 07:17 PM
compedgemarine's Avatar
are you using the actual springs on the valve or a light checking spring. if you use the real spring and a hydraulic lifter then the plunger will compress and it will look like you need a longer PR. when you figure the PR length you need to use a solid lifter or light checking springs on the valve so you get are working with the PR length when the engine is running.
Old Jan 31, 2012 | 10:44 PM
64Rocket's Avatar
you need to mill the rocker stud pads on the heads the thickness of the guide plate.
Gene
Old Feb 1, 2012 | 12:05 PM
Is machining the stud pads a common practice when switching to adjustable rockers? The reason I ask is that I did not have to do this on my 425.
If you do have to machine the pads, is the thickness of the guide plate all you cut them down or do you need to measure the thickness of the stud base as well?
Additionally, will this machining require you to machine the stud mounting holes deeper?
Old Feb 1, 2012 | 04:59 PM
64Rocket's Avatar
If you machine for 7/16 studs and you have the thick guide plates, then yes you should machine.
Now if you are using the Comp cams roller tip rocker kit, I would say no, you need longer push rods.
Gene
EightballZ
Apr 24, 2014 02:29 AM
EightballZ
Mar 24, 2014 05:03 PM
rcdynamic88
Nov 12, 2013 01:50 PM
oldzy
Jun 1, 2011 08:30 PM
defiant1
Mar 19, 2011 07:14 AM
