Rocker arm studs
Old Mar 28, 2011 | 07:29 PM
defiant1's Avatar
Question Rocker arm studs
Say, I got a set of used (less than 500 miles) set of rocker arm studs from ebay. After further inspection I notice grooves on either side of the stud shaft (right below where the bottom groove of rocker is). The groove are no deeper than 1/32" and appear to be from the rocker arm engaging the stud shaft while rocking back and forth.
Two questions:
1. What causes this?
2. Can they still be used? Can I take some crocus cloth to them to smooth out the rough edges and still use them.
The ebay seller did not notice the grooves and compensated me for them. And he allowed me to keep them. So before I trash them, I want to make sure they could be used.
d1
Old Mar 30, 2011 | 05:46 PM
jag1886's Avatar
Did you use guide plates for the push rods??
Old Mar 30, 2011 | 08:49 PM
defiant1's Avatar
Yes, guide plates were used for the push rods. Maybe the push rods were damaged or bore was out of whack?
I got the set used, and the previous owner said he only used them for 500 miles on his 455 before switching heads.
I am just looking to see if I can install the slightly damaged studs and if so, what I can do to ensure I prevent the same thing from happening.
d1
Old Mar 31, 2011 | 04:28 AM
InfoJunkie's Avatar
InfoJunkie
It sounds as though the rocker slot was too small for the cam being used or the valve geometry was incorrect.
Yes. You must remember the metal has been fatigued as is now not as strong it once was.
ihengineer76
Jun 14, 2012 04:31 PM
Delmont 88 PA
Mar 21, 2012 04:52 PM
Railguy
Dec 31, 2011 07:21 PM
CutlassLegend
Sep 21, 2011 02:56 PM
330noob
Aug 30, 2011 10:07 PM
