Rocker arm stud - bolt broken
Old August 3rd, 2014, 10:37 PM
1966Oldsmobile's Avatar
Hello, yesterday I mounted the rocker arms on my ´66 330cui small block. I mount the bolts with 35 lbs/ft and the bolt broke!!! Ok, could happen I thought, so I tried again with another bolt. This one broke again!!! See picture
My questions are:
- Is 35 lbs/ft to much
- are the original bolts harder than "normal" bolts
- is there are special position when mount the bolts? Valve closed or something?
Thank you very much for your help
Daniel
1966Oldsmobile is offline
Old August 4th, 2014, 04:08 AM
This is not surprising, as the specified torque is 25 ft/lbs.
Generally, it is better to torque each cylinder with the valves closed, though, personally, I don't think it matters much.
I do not know the hardness of the rocker pivot bolts.
MDchanic is offline
Old August 4th, 2014, 04:25 AM
Thank you very much! Will try 25 ft/lbs :-)
Old August 4th, 2014, 04:41 AM
All of the torque values are in the Chassis Service Manual, which is available for free from WildAboutCars, though in this case, I suspect you just remembered the number wrong.
Note that the 1966 manual will have an incorrect torque listed for the harmonic balancer bolt - it is actually "160 ft/lb minimum."
Good luck!
MDchanic is offline
cwb442
January 26th, 2015 05:13 PM
HiCompOlds
July 6th, 2014 09:00 AM
EightballZ
March 24th, 2014 05:03 PM
rcdynamic88
November 12th, 2013 01:50 PM
halfmoontrail
January 9th, 2013 09:17 AM
Quick Reply: Rocker arm stud - bolt broken
