Rochester 4 barrel carb
What year 330? The 64-65 330s used the square-bore 4GC. The 66-67 330s used the Quadrajet. An emissions-compliant 1980s Qjet will bolt on to the 66-67 manifold. That's about all you can say for it. Connections will be different, throttle linkage will be different, and the one certainty is that the jetting will be wrong.
It will "work", but it won't be a bolt-on. 7028250 is from a 1968 350. The throttle linkage and the divorced choke are both different from 1967 to 1968. A correct 1967 carb would be best. Failing that, a 1970 carb (7040250) with the integral choke would be easier to convert to electric, solving the choke problem. You'll still need to modify your accelerator rod to fit any 1968-newer Qjet, however.
It is worth the time to try to find the exact carburetor by #. This will alleviate fabricating/modifying things to a level that will work but never really be correct. Think of "universal fits all" vs the "correct" stuff...there is a big difference.
Good luck!!!
Good luck!!!
