Rev Limiter Question.
Old Jan 18, 2013 | 01:02 PM
tcarroll's Avatar
I have an original 1968 Rocket 350 engine i had rebuilt. It is all stock except for the mild cam that was put in it , HV oil pump and the 4 bbl rochester has been rebult with hi perf accel pump rods needle and seat and air orifices drilled out. I have a pertronics electronic ignition in the stock distributor and it has a rev limiter. What is the max rpm I want out of this motor? Where should i set the rev limiter? Any suggestions would be appreciated....T
Old Jan 18, 2013 | 01:16 PM
I'd set it to 4800 - 5000 rpm.
Old Jan 18, 2013 | 03:19 PM
krooser's Avatar
Hot Rod Has Been
The cam should dictate the max rev's.... assuming everything in the engine is OK.
Old Jan 18, 2013 | 03:51 PM
cutlassefi's Avatar
Actually imo the valvesprings will dictate what a safe rpm limit will be.
You can have a cam that breathes to 7000, but if the valve springs let the valves float at 6000 then 5800 is your limit. It'll quit making power once the valves start to float anyway. There's no sense in spinning it past that point.
I'd set it at no more than 5200 or so unless you know exactly what spring is in it.
Old Jan 18, 2013 | 06:56 PM
krooser's Avatar
Hot Rod Has Been
I was thinking max. practical rpm's vs. max before valve float...same church, different pew, I guess.
Old Jan 18, 2013 | 07:22 PM
tcarroll's Avatar
Thanks guys I'll ask my buddy who built the motor for me. The factory setting is 5500 rpm but you can set it any where from 4000 rpm to 9000 rpm.
Old Jan 24, 2013 | 08:23 PM
tcarroll's Avatar
My buddy who built the engine thinks 4500 rpm is good. Thanks for all your help.
dc2x4drvr
Aug 30, 2025 06:19 AM
randomarrival
Mar 10, 2013 07:32 PM
kips70cutty
Feb 28, 2012 08:00 PM
kips70cutty
Jan 31, 2012 06:22 PM
74 Omega
Jul 29, 2008 02:12 PM
