Replacing the carb on my 72 cutlass s... any hints/tips?
Replacing the carb and intake manifold on my 72 cutlass s... any hints/tips?
How hard would it be to do both? I have minimal mechanic skills.
I was thinking the Edelbrock Performer RPM intake manifold and the Edelbrock Performer Carburetor (600CFM 4 barrel).
Any idea on how much HP increase I would see over stock?
Hey James most of us use the assembly manual for reference, it makes it easy to see what a job will entail and what tools may be needed.
If you don't have one you should try to get one ....you can access an online one free at wildaboutcars
Why is your current set up on your car ? Qjet? Many like the qjet for better throttle response and better gas mileage. Many others run an edlebrock because in general they run ok right outta the box. If there is any HP gain I think will be small assuming a stock engine
Last edited by RetroRanger; June 19th, 2013 at 06:02 PM. Reason: I will choke the guy who invented auto incorrect
replace what? a 2-bbl?
You can shed ~40 lbs of weight if you go to aluminum intake from iron.
If your skills are minimal you might wish to recruit a veteran to assist. TEST FIT before applying gasket goo. Select the right gasket sealers. Proper torque sequence and figure- requires the instrument... Rot like that.
I dont care about gas milage. I want to build this engine up for performance.
Thanks for the link!
If your not going to change the cam and/or add compression, I'd stay with the stock or performer type intake with the q-jet. I'd work on the tune of the carb & ignition & a low restriction dual exhaust. Sometimes putting an rpm intake on a stock engine will decrease the engine performance, basically loosing your low end torque for little top end.
Then there's always rear gears & a higher stall converters too.
http://www.summitracing.com/parts/ur...FSzhQgodQCQAfQ
The tech at Summit said that it would fit my stock 350.
It'll fit your intake but its jetted for a 455. It'll run too rich.
I'd try to have your carb rebuilt, they can fix the throttle shafts, plus it jetted( close already) to your engine. Do you have any carb gurus around your area?
If you're not doing anything else, I wouldn't swap the intake. There's minimal performance to gain on a stock motor (other than weight), and there's a funny learning curve on getting intakes to seal properly.
You can just swap a carb onto the stock intake. I'm a big fan of the qjets, but there's a lot to learn about them to get them right. If it was me, I'd go for the Street Avenger carb.
The problem you have is your manifold is for a spread bore carb. You primary choice without an adapter is a quadrajet. Since your engine is basically stock, why not just go to an autoparts store and purchase a carb specifically for your engine. This way if it does not work right you can exchange it without a bunch of freight.
I would also tend to believe that there is a carb rebuilder somewhere close to you if wish to rebuild yours.
The shop said I was losing air from the base of the carb when they tested it which is probably causing my hesitation start from stop.
Also, can you post a link to the Street Avenger? Im curious as to what you are talking about.
Thanks.
skryla
December 25th, 2011 08:36 AM
cluelesscutlass
August 14th, 2011 12:06 AM
STRETCH1
Body work
February 17th, 2010 07:09 AM
