Removing engine/trans with alum intake manifold?
Old Sep 26, 2010 | 09:32 AM
oldzy's Avatar
I am going to remove my 350 engine/trans soon, but it still has an Edelbrock aluminum intake manifold. Is it safe to put a carb plate on and lift everything out by that way?
The last time I removed the engine/trans as a combo, I never had that carb plate, and just mounted to the heads.
Old Sep 26, 2010 | 09:45 AM
With an aluminum intake, I mount your cherry picker chains to the heads with grade 8 bolts.
Old Sep 26, 2010 | 09:50 AM
citcapp's Avatar
X2 on this method
Old Sep 26, 2010 | 10:25 AM
Rickman48's Avatar
Only seen it on T.V. - don't know anyone who's done it, or had a breakage problem, [which would be MUCHO EXPENSIVE] but I've too much respect for Murphy and his Law!!
Don't do it X3 is my vote!
Old Sep 26, 2010 | 07:25 PM
X4. I've stripped enough carb mounting bolts on aluminum intakes just installing the carb to be worried about lifting plates. Why take the chance?
Old Sep 26, 2010 | 07:33 PM
oldzy's Avatar
I feel that way also. I don't want to ruin the Edelbrock RPM intake (although that would be the least of the worries if the engine fell). Since I stupidly scrapped my stock intake long ago, I will have to use the heads for now. I will have to put an ad up also b/c I need a decent stock intake anyway.
Another related question... I have Hooker headers and the pass. side will not slide out (it is completely unbolted), as it keeps hitting the oil filter. I put these headers on about 20 years ago, and can't remember how I put them on. Does the oil filter need to be removed? I also have that huge A/C thing on the firewall. The pass. side header is the only thing left that seems in the way of removing the engine/trans.
tx
Old Sep 26, 2010 | 07:52 PM
tx
On every A-body Olds I've ever put headers into, the oil filter AND the adapter need to come off. Three bolts hold the adapter to the block.
Old Sep 26, 2010 | 07:55 PM
oldzy's Avatar
Joy.
Can't I just pull the engine, and wiggle the header out along with it?
Old Sep 27, 2010 | 01:56 AM
64Rocket's Avatar
Yes you can pull the engine and work the header out. It is a pain in the *ss to pull both the engine and trans. I would suggest you do the engine by itself and then drop the trans. Makes less of a mess on the floor.
Gene
junior supercar
May 6, 2015 10:49 AM
turboaudi
Aug 11, 2012 08:35 AM
steve19
Dec 3, 2008 05:16 AM
rays1930
Aug 30, 2008 07:32 PM
dstebor
Apr 2, 2008 05:23 PM
