Rebuild 350 heads
Old Mar 30, 2023 | 08:43 PM
Jackthur7's Avatar
Rebuild 350 heads
I have a car repair in Brazil and a customer brought me an Oldsmobile Omega 74 to redo a cylinder head. I took the grinding and there was no solution, I looked for days on the internet for this cylinder head and I didn't find anything for the Rocket 350 5.7 I just read that there is a way to fit a big block cylinder head in a small block. If anyone has a link to a store that they can send to Brazil, it would be of great help, but if you can talk more about this fitting, I would also be grateful. Sorry if the translation is not good, I'm using google translator. Here below, pictures of the broken cylinder head
Old Mar 31, 2023 | 08:36 AM
67OAI's Avatar
Old(s)GuysRule
It appears that the cylinder head casting number is 411929. It should have a large number 8 cast beside the exhaust port of the number 1 cylinder. That cylinder head should be plentiful as it was available on the 350 Oldsmobile motor from 1973 to about 1980. You should place a post for a number 8 cylinder head in the "parts wanted" section of the "Oldsmobile parts" section in the "classifieds".
Old Apr 1, 2023 | 04:36 PM
67OAI's Avatar
Old(s)GuysRule
To answer your question about using big block heads, they will bolt in place and all external dimensions and accessory attachment points are the same as a small block head, but the intake ports are much larger and you may have trouble getting a good seal on the intake manifold as a result. The combustion chamber on the big block head is much larger than the combustion chamber of the number 8 cylinder head so that low compression motor would have even lower compression. Not a good option in most cases.
72OldsCut<
Oct 31, 2022 11:20 AM
wagsk2000
Jan 2, 2021 07:38 AM
L69
Mar 15, 2020 09:37 PM
mkpola
Nov 27, 2012 06:27 PM
oldcutlass71
Dec 1, 2007 03:21 PM
