Ready To Run Distributor Install
I have a Mallory Comp 9000 (PN 9163401) ready to run distributor that I would like to install next weekend and need some assistance.
I have a completely stock points unit with the stock coil setup, but I'm not familiar with ballast resistors or connecting them to a stock system. Only ever connected pickup cables and crank triggers before.
Do I need to run a ballast resistor?
What color is the stock ignition wire going to the + side of the coil?
What is removed from the stock system that is no longer needed?
The Mallory has the following:
See instructions for the Mallory - http://www.jegs.com/InstallationInst...50-3748201.pdf
Also, have an MSD 6AL that may go in, but I'll get the distributor installed and working before pursing that end of it.
Thanks.
Thanks.
jslabotsky
April 21st, 2012 08:50 AM
monzaz
September 5th, 2011 10:45 AM
