Radiator Recommendation 1972 Cutlass Supreme with 4bbl and AC
Hi! As I've been working on getting the car running on its own, my heater core (which I believe is original) started leaking all over the floor of the garage and the cutlass. So if I'm going to replace that, I figured I'd probably replace the radiator as well. Any recommendations for both the heater core and radiator? What's good and whats garbage? And am I looking for a 3 or 4 row radiator? Or should I have this one rebuilt? What does that run? I'll have to look oto see if it is original or not. Is this one any good?
https://www.napaonline.com/en/search...=nol-veh-conds
Thank you!
Chris
https://www.amazon.com/Spectra-Premium-CU161-Complete-Radiator/dp/B000C7QGTA/ref=sr_1_5?dchild=1&keywords=1972+oldsmobile+cutlass+supreme+radiator&qid=1593980565&replacementKeywords=radiator&sr=8-5&vehicle=1972-51-576------------&vehicleName=1972+Oldsmobile+Cutlass+Supreme
or either of these?https://www.napaonline.com/en/search...=nol-veh-conds
Thank you!
Chris
I would not recommend replacing the radiator just because the heater core leaked. Over the years I have replaced the heater core probably 5 times without ever touching the radiator. Personally, I am not a "replace it just because" kinda guy, I replace things when they are broken and leave working stuff alone.
If you are seriously concerned about the radiator's integrity, bring it to a radiator shop and have it inspected and pressure tested.
This post has a lot of pictures and info that may help you to determine what you have:
https://classicoldsmobile.com/forums...ipping-119733/
If your not worried about it looking stock, I put a all aluminum Cold Case radiator in my car and am very happy with it. It is a two row radiator but the tubes are 1.125" wide and it cools as good or better than a traditional 4 row. Actually it would look almost stock if you fogged it with some black paint. just my 2 cents.
Gary
Gary
Gary
Gary
I have The Cold Case Radiators in both of my cars. They are both direct fit and was able to use my top plate on both. Both cars came with 4 core radiators.
https://www.summitracing.com/parts/rad-gma42a
Texas442
December 8th, 2010 08:16 AM
