Radiator Help
Old Aug 19, 2015 | 06:18 PM
harpelt's Avatar
Radiator Help
Got a hole in the original radiator on my 1968 Cutlass Holiday Coupe. 350 CID with AC and Automatic. Tried buying a replacement from Autozone and they sent a Spectra Premium that doesn't fit (too deep and doesn't slide into lower saddle mounts.) Any suggestions on a vendor and Part number that has the right one?
Old Aug 19, 2015 | 06:45 PM
Oldsmaniac's Avatar
You can try and have your original one recored by a radiator shop or repaired if solid enough...
Old Aug 19, 2015 | 10:08 PM
Yep. I had a new core installed in my original end tanks. Got a 4 row high efficiency core to help with summer temps here in Phoenix. Fits and looks just like the original as you can't really see anything other than the end tanks.
Old Aug 20, 2015 | 06:18 AM
harpelt's Avatar
Don't know why I didn't think of a recore. I'll give that a shot!
Old Aug 20, 2015 | 07:17 AM
76olds's Avatar
Hookers under Hood
When my 3 row copper core rad sprung a leak I was surprised that most of the Rad shops had closed in my area. So I purchased a rad from summit (Be cool) 2 row Aluminium nice rad much lighter than the original. It took a little work to get it to fit but I made up a couple of aluminium bracket along with spacers for the top plate to compensate for the small height difference.
Hope this helps
Eric
Old Aug 23, 2015 | 06:40 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Griffin Dominator if you can't get yours recored. Just measure and make sure the A/G body rad will fit, it will not fit a G body.
Old Aug 24, 2015 | 12:32 PM
1BOSS83's Avatar
x2..it will give you fits but will most certainly NOT fit..
Old Aug 26, 2015 | 06:33 AM
The Griffin Dominator F body rad is the one that fits the G body.
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
richeyb
Oct 29, 2010 09:54 AM
Iragh
Nov 17, 2008 03:41 PM
