Question about my 350 olds
It's a 350 Olds and I bought a Holley Air Breather for the car but i'm wondering.
What do most people do with the T.V.S (Thermal Vacuum Switch) that fits in the stock air breather, Since i'm putting the Holley Air Breather on i wont need the Damper in the stock air breather, But do i need the rear vacuum brake. Or just hook the air supply line directly to the rear vac brake
If anyone can assist me with this i'd be much obliged.
By "air breather" do you mean "air cleaner?"
By TVS, do you mean the little vacuum thingie in the air cleaner that says "AutoThermAC" on it?
By "Damper" do you mean the air flapper that diverts air from either the exhaust manifold preheater or the regular intake snorkel?
By "rear vacuum brake" what exactly do you mean?
Your power brake booster is NOT connected to your air cleaner.
What year and model is your car, and is this the original engine, and has it been modified?
Did you also change carbs or are you running the stock rochester or q jet?
