Quadrajet problems
Quadrajet problems
71 olds with a 77 350 4 barrel quadrajet. I rebuilt the carb, first time took pics and video followed the instructions to a tee. Cleaned the heck out of everything. Put it back on put gas in and it started right up, no pops stumbles or backfiring. Let the car sit for a few days won't start unless I pour gas down the carb. It stays running I can drive it around the block and it idles great. I changed the fuel filter, fuel pump, adjusted the choke and it all works great. I'm guessing the float bowls are emptying when it's not running but I figure if that's happening then it should start after cranking it for a min or so, but it doesn't start.
This is unfortunately not uncommon today if the car is not driven regularly.
emarkay
December 8th, 2004 08:23 AM
