Quadrajet problems
Old May 26, 2016 | 07:16 AM
NJRob's Avatar
Quadrajet problems
71 olds with a 77 350 4 barrel quadrajet. I rebuilt the carb, first time took pics and video followed the instructions to a tee. Cleaned the heck out of everything. Put it back on put gas in and it started right up, no pops stumbles or backfiring. Let the car sit for a few days won't start unless I pour gas down the carb. It stays running I can drive it around the block and it idles great. I changed the fuel filter, fuel pump, adjusted the choke and it all works great. I'm guessing the float bowls are emptying when it's not running but I figure if that's happening then it should start after cranking it for a min or so, but it doesn't start.
Old May 26, 2016 | 08:04 AM
Must be the start of summer heat - there have been a bunch of the same question in the last couple of weeks. Bottom line is that today's gas evaporates more quickly, causing this problem. If the check valves in your fuel pump are getting weak and/or leaking, it can be difficult to get fuel to start flowing again. Also, does your fuel filter have a check valve in it or not? Is it installed in the right direction? Do any of the rubber hoses on the suction side of the pump have cracks that could cause an air leak? All of these can cause the pump to take a long time to fill the float bowl on the carb.
This is unfortunately not uncommon today if the car is not driven regularly.
Old Feb 7, 2021 | 03:04 PM
leftlaneonly's Avatar
Does the noise get lauded if you turn the wheels = p/s pump
Old Feb 7, 2021 | 04:24 PM
gs72's Avatar
72Cutlass S
huh???
Old Feb 9, 2021 | 06:03 AM
I just read that ... and sorry I can't explain it Think I had a brain fart
Old Feb 9, 2021 | 07:50 AM
edzolz's Avatar
Also the original post was in 2016. Hopefully the problem is resolved by now.
Will22
Dec 2, 2017 05:20 AM
Wood
Aug 2, 2017 06:47 AM
denf221
Jan 30, 2017 02:30 PM
chip-powell
Jun 20, 2016 04:13 AM
emarkay
Dec 8, 2004 08:23 AM
