Push Rod Length Intake vs exhaust
Old Feb 5, 2012 | 02:57 PM
ggriffin1960's Avatar
1972 350.....Using a solid lifter,Comp Magnum Roller tip rockers, studs, guide plates and Comp push rod length checker I am getting .100" length difference between the intake and exhaust push rod length on all cylinders. Is this correct? I thought they should be the same length?
Old Feb 5, 2012 | 03:02 PM
Lady72nRob71's Avatar
Perhaps same length for only hydraulic lifters?
Old Feb 5, 2012 | 07:02 PM
Rickman48's Avatar
If you have more lift on the exhaust, that might account for the different readings.
I'd call Comp, and ask if you should run two different lengths, or split it down the middle.
Old Feb 5, 2012 | 07:20 PM
380 Racer's Avatar
Have the valves ever been replaced?
bwheeler
Feb 24, 2015 07:15 PM
costpenn
Brakes/Hydraulic Systems
Dec 29, 2012 02:53 PM
LX89mustang
Sep 27, 2012 07:27 AM
ggriffin1960
Jan 31, 2012 10:20 AM
defiant1
Apr 16, 2011 11:07 AM
