Pro Comp Aluminum Heads on SBO - Intake manifold
Old Oct 19, 2014 | 08:16 PM
rcdynamic88's Avatar
You guys here on CO have me looking at these Pro Comp heads for my SBO...I have a question about intake manifold choices, if there even are any options. On the eBay ad for Bernard Mondello's Pro Comp heads he has this in his listing:
Note: When using these heads on a small block Oldsmobile engine: 350-403 an Edelbrock 7111 aluminum intake manifold MUST be used. We also have this item available.
What is the reason for only the 7111 manifold? Intake port size? Could an Edelbrock OL4B from the past be port matched to the Pro Comp Aluminum heads?
Old Oct 19, 2014 | 08:27 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It has to do with port height, most SBO manifolds don't have enough material to cover BBO ports.
Old Oct 20, 2014 | 04:10 AM
firefrost gold's Avatar
The intake you are talking about can be had for not to much money if you dig around . The rmp is a good intake and unless you are trying to run the 70 -72 OAi I would go with the Rpm intake. The 68-to 69 style OAI will work with the Rpm with no clearance problems
Old Oct 20, 2014 | 07:05 AM
Yes, this is exactly the issue. I don't know if the OL4B has enough meat or not. Some factory iron manifolds also have enough meat to be port-matched.
Old Oct 20, 2014 | 07:09 AM
oddball's Avatar
The difference between BBO and SBO intake ports is the height, and it's all in the roof. Most SBO intakes only have enough material to cover the SBO head intake port, so putting them on an engine with BBO heads would leave a large gap at the roof of the port.
As far as I know, the Edelbrock RPM is the only one that has enough material in that area to cover the entire BBO port and can be ported to match the larger port.
Old Oct 20, 2014 | 08:15 AM
The victor also will work but is a high rpm beast .
Old Oct 20, 2014 | 10:04 AM
OldSoldier's Avatar
Car Nerd
I'm interested in knowing what intakes will fit under an OAI hood for a 70-72 with procomp heads on a SBO. Hopefully someone has gone down that road before and can enlighten me.
Old Oct 20, 2014 | 10:14 AM
The carb flange on a stock SBO sits about 1.5" lower than on a stock BBO due to the shorter deck height, so you won't have near the problem fitting under the O.A.I. with a 350. In fact, the O.A.I. adapter on SBO cars uses a taller foam ring to make up the difference. If anything, you'd just need to use the BBO foam ring.
Old Oct 20, 2014 | 10:29 AM
67 Cutlass Freak's Avatar
Don't forget to make sure you tell the supplier that you will be using these heads on a SB. You will want to shave the head to get the combustion chamber closer to stock CCs. If you are planning on using a mechanical fuel pump, the head will need to be clearanced. Smitty can help you, or Bernard Mondello. Both are great guys to deal with.
Old Oct 20, 2014 | 11:28 AM
bccan's Avatar
AFAIK RPM & Victor are the only SBO intakes w/ enough material to port match the height of BBO port. I was just paying attention to this when I swapped on Street Dominator. The SD has just enough material on the OUTSIDE to cover the BBO port which iirc appx 3/8" - 1/2" taller than SBO port.
https://classicoldsmobile.com/forums...bbo-heads.html
There are some pics posted of BBO/SBO gasket comparison, post # 115
https://classicoldsmobile.com/forums...hniques-3.html
nearma12
Mar 7, 2022 08:49 PM
smash72
Jul 6, 2015 10:04 PM
Delmont 88 PA
Jul 19, 2012 04:43 PM
Olds Man
Mar 28, 2012 06:14 PM
firefrost gold
Dec 19, 2011 01:00 PM
