power steering pump for a/c vs non a/c
Old Feb 24, 2011 | 04:30 PM
1971viking's Avatar
What is the difference? I see the previous owner replaced the power steering pump pulley with a single but kept the original power steering pump. The pulley looks bent. Maybe it is because a non a/c car has a different pulley than the a/c cars?
Old Feb 24, 2011 | 04:41 PM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
this is I know...
On a '69 350, the main pump is the same , only the pulleys are different for AC and non AC. The AC pulley is a double groove pulley and the non AC is a single groove, of course , but the single groove is back towrds the pump , so the pulley has a big 'dish' to it. . Reason I know this, the previous owner of mine started installing AC, never completed it, it has the double pulley on it and I need the single one with the 'dish', in fact I'm thinking of putting it in a lathe to see if I can cut the outer groove off... .PS. also other GM products are different ( it's an Olds only thing ) Other GM pumps are the same, but it's the reservoir that Olds made different, thinner, iI think......hope this helps
Old Feb 25, 2011 | 06:38 AM
1971viking's Avatar
Thanks for the info.
So my single pulley for a non-A/C car is mounted on a A/C car power steering pump. If the A/C pump reservoir is thicker or thinner, then that is what is throwing my pulley off.
Maybe we should trade pulley's? Mine is a single dish chrome.
Old Feb 25, 2011 | 06:50 AM
dc2x4drvr's Avatar
Check to make sure your pump bracket has the correct spacers, there are two, one in front, and the other in front of the motor mount. Here is the setup from the '70 Assembly Manual.
http://wildaboutcarsonline.com/membe..._-_Sec_6-2.pdf
Old Feb 25, 2011 | 11:21 AM
knighthawk's Avatar
I assume you cas is a non AC, and it has the single ''bent'' pulley, if so, all is fine If you want to install AC in a non AC car, you need the pulley I got. The Olds resevoirs, I thnik , are narrower than the GM ones, that plus maybe plus the brackets is what makes them different .. ALL pumps are the same ! Shaft lenghs are the same ! But, obviously, the pulleys are different. Yes, if you want the double AC pulley, we can trade, as I need the single ''bent pulley '', and I'll probabley cut it up anyway .....If your alignment is off, it could be the brackets, or spacers, minw has no spacers..........
Old Feb 25, 2011 | 02:49 PM
knighthawk's Avatar
this should be the AC pulley
Old Feb 26, 2011 | 06:21 AM
1971viking's Avatar
Thanks guys. I found my problem. I was missing on spacer and the brace that bolts the power steering pump to the side of the head.
Now where do I find that part? I am sure that will not be easy or cheap. Does anyone run with out that brace and not have a 'wobble' on the pump pulley?
Old Feb 26, 2011 | 08:43 AM
knighthawk's Avatar
while installing my PS pump yesterday... I discovered an alignment problem on mine also , it had no spacers anywhere, , with the use of a level for a straight edge, some washers in a couple places, a little bend here..... maybe you make can a brace,
Old Feb 26, 2011 | 11:57 AM
dc2x4drvr's Avatar
FYI...The spacer dimensions are as follows;
Top on water pump stud .200 (washer)
Middle between timing tab stud and P/S bracket .825
Bottom above pan rail .390
2 & 3 could be fabbed out of steel tubing, or stack washers to req. thickness.
e.cast728
Apr 7, 2014 04:14 AM
nicks1966
Jan 12, 2014 01:46 PM
Jul 1, 2012 03:36 PM
Uly49
Oct 20, 2009 07:11 PM
mcutlass1969
Jan 8, 2007 06:36 AM
