Popping from exhaust problem
Old May 21, 2025 | 11:44 PM
Sander's Avatar
Hi guys
First some info
Oldsmobile cutlass supreme 4 door 1966
​​​330 v8 th200-4r
dual exhaust
Last week my car started popping from my exhaust when i let go off the throttle at 3000rpm or below.
it got worse and worse the more i drove the car. And now it popping from the exhaust when i let go off the throttle at any rpm. The sound does seems to come only from the driver side exhaust. (I have true dual exhaust but without a H or X pipe or something like that)
it driving me mad. The car does drive fine and runs perfectly. Does not mis and has all of its power.
i checked all the plugs and they are fine. All cilinders are firing just fine
A couple friends of mine think my exhaust manifold is leaking somewhere. Can this be true? I did not have time to check yet.
i tried to film the isue but i can only upload the audio, i hope you guys can hear it and help me?
File Type: mp3
Old May 22, 2025 | 06:31 AM
Dynoking's Avatar
I agree with your friends. You have an exhaust leak that allows oxygen to mix with hot exhaust and ignite un-burned fuel. The leak(s) may be slight and hard to hear/pinpoint. Have a helper hold a big wadded up ball of rags over one tail pipe at a time. With the engine at idle speed squirt a couple shots of engine oil in to a small open intake manifold vacuum source. The resulting smoke will show up any leaks.
Old May 22, 2025 | 07:59 AM
Hammerdrop's Avatar
An alternative would be a Smoke Machine inserted into the tailpipe.
mb13
Mar 25, 2024 05:42 AM
Reese Neis
Jun 19, 2021 11:53 AM
dalilama
Jun 30, 2016 11:37 AM
hmartin
Ninety-Eight
Jan 18, 2012 06:22 AM
ragtop71
May 4, 2011 04:25 PM
