Piston volume stock style 403 pistons
How to calculate Piston volume in ccm from the pistons below
Recessed piston head is 0.150 inch deep x 3.250 inch diameter.
http://www.summitracing.com/int/part...np30/overview/
It's the calculation of the volume of a cylinder. Google is your friend here.
Just use this calculator, but you will need to use the radius (diameter divided by 2):
https://www.google.com/search?q=volu...utf-8&oe=utf-8
Then convert cubic inches to cubic centimeters:
https://www.google.com/search?q=cu+i...utf-8&oe=utf-8
3.25x3.25x.150x12.87 will give you the cc's.
88hurstolds
January 20th, 2020 11:39 AM
oldzy
Suspension & Handling
June 12th, 2010 10:02 AM
