Omega Heater Hose Replacement
Old December 4th, 2013, 06:22 PM
hardgreg's Avatar
I have a 1977 Omega, and I am working my way thru the coolant system. Iwas planning on replacing the heater hoses as well, but the firewall access to one of the hoses is not evident. I was wondering if anyone has pulled the heater hoses off an old omega, and provide any advice?
hardgreg
hardgreg is offline
Old December 4th, 2013, 07:59 PM
If it's the same as a 77 Nova, the hoses are clamped on the end of the heater core tubes. Remove the clamps and you may have to cut the old hoses off.
oldcutlass is online now
Old December 12th, 2013, 09:46 PM
Hookers under Hood
76olds's Avatar
Like Eric said, cut them off with a knife exacto works gd . By the time I was done pulling and trying to twist mine off it was too late. Yup the heater core started to leak after I put the new hoses on. Then oh what a job putting the new heater core in.
76olds is offline
Old December 12th, 2013, 11:59 PM
nsnarsk65cutlass's Avatar
hardgreg
Does it have AC?if so i think the inner fenderwell is in the way and may have to be removed,be carefull when removing the clamp and hose or you will be replacing the heater core,cut the hose off after clamp removal.
nsnarsk65cutlass is offline
Old December 13th, 2013, 05:44 PM
hardgreg's Avatar
Thanks it does have AC and that seems to be significantly in the way
hardgreg is offline
Sampson
March 24th, 2015 09:33 AM
QS442
November 9th, 2013 06:11 AM
herdez55
May 22nd, 2012 04:49 PM
tim72
May 15th, 2009 09:09 AM
Colorado Olds
March 2nd, 2008 01:57 PM
Quick Reply: Omega Heater Hose Replacement
