Oldsmobile Engine Identifaction Needed
Old Jul 30, 2007 | 04:38 PM
65DOMINATOR's Avatar
HELLO EVERYONE I NEED HELP . I HAVE A 65 PONTIAC TEMPEST WITH AN OLDS ENGINE SITTING IN IT. I NEED TO FIND OUT WHAT ENGINE THIS IS. CAN SOMEONE HELP ME TO IDENTIFY? I CAN SEND PHOTOS AND ALSO LOOK FOR NUMBERS. I JUST REALLY DON'T KNOW WHERE TO START. MY EMAIL IS healeyheaven@rock.com I WILL REALLY APPRECIATE ANY HELP THAT SOMEONE CAN GIVE ME.
Old Jul 30, 2007 | 04:46 PM
don71's Avatar
same but different
Can you post the casting number on top of the timing chain housing? Its right behind the top of the water pump.
Old Jul 30, 2007 | 06:06 PM
The Casting Number On Top Of The Timing Cover Is 395558 And Then A Large 2 The Head Id Number Is 5 And The Vin Number Below The Head Id Is 39m160462. What Does All This Mean???
Old Jul 30, 2007 | 06:14 PM
texasred's Avatar
Tom Servo's Stunt Double
68-72 350 engine. (The Olds FAQ incorrectly says 68-70)
68-69 heads. You have the best flowing stock heads and a great small block Olds motor there.
A guy up the street from me has the same engine in a 69 Firebird convertible.
C.J.
Old Jul 30, 2007 | 07:37 PM
Actually, the 39M160462 is called the VIN-derivative. The 3 means it's Oldsmobile, the 9 means it's a 1969 model year motor, and the M means it was built at the Lansing, MI factory. The last six digits correspond to the build sequence number of the car it came in. The head and block casting numbers are consistent with a 1969 motor.
Old Jul 30, 2007 | 09:05 PM
Thanks to evryone helping me to identify this engine. now I will have to see what tranny is hooked to it being which automatic either stock pontiac or the oldsmobile tranny. or did that model only have a powerglide? Does anyone know what that engine would have for horsepower? It is a two barrel engine but of course I can change that... Thanks for all the help again
Old Jul 31, 2007 | 10:39 AM
Olds and Pontiac motors have the same bellhousing bolt pattern and will bolt to the same transmissions.
Old Aug 1, 2007 | 08:39 AM
Jokers69's Avatar
Senior Moment
65 Tempest.. nice car. 65 Tempest with a 69 SBO.. nicer car.
Old Aug 1, 2007 | 09:42 AM
Thanks but I have to restore the old car to make a one of a kind cruiser.
805cut
May 3, 2012 08:11 PM
scott71
Mar 5, 2010 10:58 AM
65DOMINATOR
Jul 30, 2007 05:09 PM
