Oldsmobile 307 5A Head Question
Old Apr 9, 2013 | 05:13 PM
pherbicide's Avatar
Hello everyone,
I have an '83 Oldsmobile 307 engine pulled out of a recently acquired Buick Riviera that I'm looking to have a little work done on. I've heard plenty of information regarding the 307, both yay and nay. Regardless of which, the engine landed in my lap, and I will be sticking with it for the time being. The engine was outfitted with 5A heads, and I'm looking for a little more information about these heads, specifically the chamber size of the heads. Does anyone have a spec sheet about these heads in particular that might have that information?
Thank you,
densen
Old Apr 9, 2013 | 06:22 PM
TripDeuces's Avatar
BTR lists them as 67 cc
Old Apr 10, 2013 | 03:43 PM
pherbicide's Avatar
Thank you for your response TripDeuces. If I may be so naïve, what or who is BTR?
Old Apr 10, 2013 | 04:46 PM
Redog's Avatar
A 5A headed 307 SBO has to have a A4 manifold and is the better of the 307's. it a big car like the Riv, do you know if its the "9" motor or the "Y" motor. The 9 has a hotter cam and is found in the 442 and Hurst of that year and its in a few of the bigger GM cars like the Caddie
What is the VIN of the Buick? That is the only way your going to tell if its a Y or 9, assuming the motor is orginal
Old Apr 10, 2013 | 04:57 PM
Octania's Avatar
But, why?
Leave the 307 alone, use it until it dies
Old Apr 10, 2013 | 05:01 PM
TripDeuces's Avatar
Bill Trovato Racing
Old Apr 11, 2013 | 08:44 AM
455man's Avatar
Some good info on this site.
http://www.oocities.org/teamcat101/Olds307Tech.htm
Old Apr 12, 2013 | 09:39 AM
pherbicide's Avatar
Wow, thank you all for your responses.
The engine itself is a Y model, completely stock.
Old Apr 12, 2013 | 02:31 PM
Redog's Avatar
the Y is rated at 140 HP and 255 ft/lb
Old Apr 12, 2013 | 02:52 PM
DoubleV's Avatar
Not that it matters, but the 5A headed Y 307 was actually rated at 150 HP. The 7A headed Y was rated at 140 HP. Either way, they're both underpowered!
Olds Scott
May 29, 2013 08:15 PM
carbonf00tprint
Nov 4, 2012 07:53 AM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
