olds 403 stroker
olds 403 stroker
what rods and pistons would i need to build the 403 stroker? I have a 330 forged crank i want to use. do i have to have the crank welded and ground or can i use longer rods and a shorter piston?
First, with windowed main webs, a 403 stroker may not be the right way to go. The lack of strength + the extra strain of a longer throw may just prove to be disasterous.
Now the term stroker doesn't mean change the pistons and rods to make it a stroker. What you are doing is undercutting the rod journals offcenter to change the centerline of the journal.
So with a 2.5" stroke, you undercut the journal .25 OUTWARDS from the centerline, you now have a 3" stroke... It adds .25 to the top and bottom of the stroke. On the same note, if you cut .25 off inwards of the centerline, you have destroked to 2"... (for clarification, inwards being removing material from the side facing AWAY from the main journals, and outward being removing material from the side facing TOWARDS the main journals.)
So, what you need to do is make sure the journals are clean. Measure the diameter, then find a rod with the length and the journal diameter you need and cut the crank off the centerline down to the new rod size. Watch out because you CAN go to far and weaken the crank...
People with more experience than me can fill you in with specifics and correct me if I'm wrong.
![](http://www.fordmuscle.com/archives/2003/09/stroker/images/offsetgrind.gif)
I'm having mine welded and then ground to a 2.00 rod journal size, stock is 2.123. It will be stroked to 3.75, 6.00in. rods and a piston with a compression distance of 1.425. I'm doing a 350 though, not a 403 so my pistons are off the shelf. Yours would probably have to be custom made.
CutlassEFI probably knows more about the SBO stuff than I do,but I think you can offset grind a 330/350 crank to 3.50" stroke,with a 2.00 SBC journal,no welding.Yes?
put the longest rod in there possible,& a short,lightweight piston.This will help take some stress off the mains,but is not a cure-all.What are your expectations with the car?
a fun street car with close 500 ft/lbs of torque. Its going back into a 79 t/a. Ive seen an article where a guy stroked it and he got 505 ft/lbs of torque and ive seen articles where guys just use a stock cast or forged crank and make real close to 500 ft/lbs if not a little over 500 so i dont even know if its worth stroking. I wont be spinning it over 5500.
and the problem is i cant find a short piston for this thing. The bore is huge, 4.375. will i have to have a custom piston made? i have the kb 0.24 Hypereutectic piston right now but i can return it.
I have a little advice I know you like the Olds engine, but with 79 Transam you have a lot of engine options. The put Pontiac, Chevy and Olds engines in them. Their something like 10 different engines that came in it. So if you want to build a powerfull engine you have a few more options.
yeah i know. i just already have alot of the olds engines parts so i want to use them. im just kinda at the pint in my build where it wouldnt hurt me very much to change engines so im looking at all my options. Another option would be the diesel block right?
You know you already have a lot of good parts. I say you can put to gather a very nice 403 with what you have. It will be a very strong engine. I think it will be a lot more engine than peoples giving it credit for. Just remember it doesn't matter how much power an engine make unless you can put it to the ground. So what's your plans for the rear suspension to get the power to the ground.
i bought new stock leaf springs, new stock shocks, lakewood traction bars, beefier rear sway bar, and sub frame connectors. Its not a whole lot but im not to concerned. the car will just be for fun and burnouts are always fun
You won't make 500 ft/lbs with that 403, but you won't need it. My 355 makes 375 ft/lbs and will fry the tires at will. Don't over think it, you have the engine, you have the parts already, 409 cubes is plenty. Assemble it, tune it, have fun driving it.
They are OK if you don't. You are making this way too complicated. All you want is a fun car to drive, right? Hit the cruises, a little stoplight fun, bust the tires loose on occasion? You don't need light rods or custom pistons for that.
403's came with a very nice rod.You can recondition them,& reuse them in your build,as long as you keep the crank as-is,& don't alter the journal sizes.
If you ever get to the point where you want to make some serious power,then yes,the diesel block is the way to go for a SBO.
All excellent posts. A 403 will put out all you need. Couple that with a good rear gear and it'll be fun. Picking the right cam will be as important as alot of other things.
Again, Torque can be made without a big long stroke. Want to guess what the stroke is on a typical Nascar motor? 3.25, Bore is 4.185. They make plenty of torque down low to come off the corners and then spin em up to make hp on the top end. Shorter stroke means lower piston speeds as well. There are pros and cons to almost every scenario.
88hurstolds
January 20th, 2020 11:39 AM
